Re: proper PCV valve & grommet for a '67 440
[Re: JohnRR]
#1658960
08/15/14 07:25 PM
08/15/14 07:25 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
Correct valve is steel....However, I am under the impression that there will be no grommet, rather the valve is fitted into a steel cap that pushes onto the valve cover like the breather does. 1968 had a grommet and used the steel valve. Correct me if I'm wrong.
[Re: gassy66]
#1658961
08/15/14 07:32 PM
08/15/14 07:32 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
How do I get in touch with joesixpack???
PM him ???
[Re: superwrench]
#1658963
08/16/14 08:04 PM
08/16/14 08:04 PM
Posts: 21,442 It's a dry heat
gtx6970
It's a dry heat
1967 is the same as 1968 pretty sure the last year for the cap style was 1965 ( except Hemi which was 1969 )
as an fyi, the 1969 and older style pcv valve are getting tougher and tougher to find. I have about a half dozen ( none are for sale )
http://www.ebay.com/dsc/6000/i.html?LH_TitleDesc=1&_nkw=2808622&_rdc=2
[Re: gtx6970]
#1658964
08/17/14 04:50 AM
08/17/14 04:50 AM
Posts: 7,052 Madera, CA.
MowP4rsn
Madera, CA.
I think this Dorman grommet from their Help! line might work. I know the set up you have as my car has it too
[Re: MowP4rsn]
#1658965
08/17/14 04:57 AM
08/17/14 04:57 AM
MowP4rsn
Madera, CA.
The PC valve itself isn't really a "wear item", so if it rattles it doesn't need replacing. If you are going for "authenticity", then the steel PC valve is the one to get. If you're not concerned with looks, then get this Standard Motor Products V180 PCV Valve and save yourself some $ I have one on my car, it fits and works fine.
