new oil system or rack and pinion #1642615
07/05/14 11:41 PM
07/05/14 11:41 PM
Fremont, California Bay area
blindboyscuda Offline OP
ok so I want to get rid of the extremely high ride height. i currently have the 10 quart miladon oil pan with the swinging pick upand i have had to use the torsion bars to make the ride height high enough so that the oil pan doesn't drag. the engine is making 600 hp so is the swinging pick up needed or can i go back to a static pick up and use a different oil pan? if the swinging pick up is preferred or suggested then i am goingn to switch to rack and pinion. so what would you suggest a new oil system or go to rack and pinion?
Re: new oil system or rack and pinion [Re: blindboyscuda] #1642616
07/05/14 11:49 PM
07/05/14 11:49 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
get a pan with wings so it still maintains the amount of oil you want but don't hang too low. or make your own like I did.
Re: new oil system or rack and pinion [Re: blindboyscuda] #1642617
07/05/14 11:52 PM
07/05/14 11:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Both... the oil pan is a little cut and weld... I
am right at 600hp (SB) and I use the static pick up
Re: new oil system or rack and pinion [Re: MR_P_BODY] #1642618
07/06/14 11:51 PM
07/06/14 11:51 PM
is there a rule of thumb for static pick ups and how much hp they can support? when I built the engine I did not drill it for 1/2", so it is stock. what oil system would support 600 hp and at what point should a swinging pick up be used along with higher pressure and volume oil pump?
Re: new oil system or rack and pinion [Re: blindboyscuda] #1642619
07/07/14 12:00 AM
07/07/14 12:00 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Sounds like your talking BB but I know plenty of guys
that make 600+ hp on the stock pick up... a 3/8"
hole can supply a lot of oil under pressure
Re: new oil system or rack and pinion [Re: MR_P_BODY] #1642620
07/07/14 12:39 AM
07/07/14 12:39 AM
yup BB. is there a reason why I shouldn't use the
stock oiling system? probably going to be doing upgrades soon like a roller cam and tunnel ram so the hp might be around 650 soon.
Re: new oil system or rack and pinion [Re: blindboyscuda] #1642621
07/07/14 12:45 AM
07/07/14 12:45 AM
MR_P_BODY Offline
MR_P_BODY  Offline
JMO.. but if your planning more rpm then I would drill
the stock set up to 1/2".. you just need to be careful
when doing it
Re: new oil system or rack and pinion [Re: MR_P_BODY] #1642622
07/07/14 03:31 AM
07/07/14 03:31 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
plug the stock pickup hole & go with an external static pickup & pump cover like my earlier pic. excuse the metric sizing but that's what we have down here, 1/2" stock pickup is only 12mm dia, the single static pickup is 16mm dia, that's 25% larger plus there's no sharp 90* turns inside the block restricting the oil flow. I'm using this single static pickup on a 750HP engine & my bearings(clevites. not speedpro) look almost good enough to reuse again @ engine freshening time.
Re: new oil system or rack and pinion [Re: rebel] #1642623
07/07/14 04:02 AM
07/07/14 04:02 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
What's the little valve in the top of the pan?
Re: new oil system or rack and pinion [Re: Stanton] #1642624
07/07/14 05:17 AM
07/07/14 05:17 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
oil temp sender for the guage
Re: new oil system or rack and pinion [Re: blindboyscuda] #1642625
07/07/14 01:40 PM
07/07/14 01:40 PM
MrP is dead on, my pump gas Duster motor, 518 C.I. low deck with a roller cam, made 727 HP at 5600 RPM the last time it was on the DTS engine dyno in Klamath Falls, OR(4300+ ft elevation ) I used the Speed Pro, Federal Mogul narrow full groove main bearings(pt # 4094M, I think) and the same brand rod bearings, BB Chevy rods size though Both mains and rods had more than .0032 clearances, I used a high volume oil pump and cut the bypass spring down so the motor had 65 lbs pressure at or above 5000 RPM with hot oil, I used 5W20 Wt Valvoline non synthetic . I bought and used a stock Mopar replacement oil pan, (6 quarts ) 1970-71 440 6Pak and 426 Street Hemi B and E body with the stock 3/8 440 6 Pak pickup and a stock Mopar windage tray I do make my own crankshaft scrapers to help keep the oil in the pan instead of being whupped up into a froth around the crankshaft at high RPM Lots of solutions out there IHTHs
Re: new oil system or rack and pinion [Re: blindboyscuda] #1642626
07/07/14 03:45 PM
07/07/14 03:45 PM
Real North Cal.
66er Offline
66er  Offline
Real North Cal.
I think it has more to do with RPMS Than HP. A single line can support up to 7000 RMPs anything over that need a double line(one on each side of the pumps stator). The swinging pick up is installed to accommodate the style of pan that you are using ie: large rear sump or dragster style). I've used a center sump with a static single line for 8 year now. I have about 650-700 hp and shift at 6700 RPMs.
Re: new oil system or rack and pinion [Re: 66er] #1642627
07/07/14 11:21 PM
07/07/14 11:21 PM
I would shift my Duster stroker motor between 7000 and 7300 in each gear, lots of laps that way with no oiling issues
Re: new oil system or rack and pinion [Re: 66er] #1642628
07/07/14 11:36 PM
07/07/14 11:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I was running 8200 on the stock 3/8 pick up with a
little blending on the pump housing.. that was with
.003/.003 clearances on the mains and rods in a SB
Re: new oil system or rack and pinion [Re: MR_P_BODY] #1642629
07/08/14 12:12 AM
07/08/14 12:12 AM
gregsdart Offline
gregsdart  Offline
I have may runs going through the traps with a single pickup deal at 7800 rpm. 528 stroker.
Re: new oil system or rack and pinion [Re: gregsdart] #1642630
07/08/14 02:43 PM
07/08/14 02:43 PM
Real North Cal.
66er Offline
66er  Offline
Real North Cal.
Sound like a double line pickup is overkill for most applications. As long as the pressure stays up where it should be, everything is a-ok. I think the to line systems stand a better chance of losing prime anyway. You could also use a swinging pickup with just one line instead of two.
Re: new oil system or rack and pinion [Re: MR_P_BODY] #1642631
07/08/14 02:51 PM
07/08/14 02:51 PM
Real North Cal.
66er Offline
66er  Offline
Real North Cal.
A small block oil system is a little different than a big block. The pump is way closer to the oil level in the pan. The stock style pickup is way shorter and doesn't have to make a transition though the casting of the block. The extertal -12 pickup hose may be overkill but it let's me sleep a little easier.
Re: new oil system or rack and pinion [Re: blindboyscuda] #1642632
07/08/14 03:01 PM
07/08/14 03:01 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Been running a stock but 1/2" internal pick up for almost 14 years and no issues at all even above 7000 rpm`s and that`s w/6-7 quarts in an 8-quart pan.
Re: new oil system or rack and pinion [Re: rebel] #1642633
07/12/14 07:30 PM
07/12/14 07:30 PM
ya its about 500 cubes and is only spinning around 6k max. it has 2.20 chevy rods and has good oil pressure with a single external line with a swinging pick up using brad penn 10 40. the oil pan is just huge. it is 10 quarts of oil and I have to worry about going over speed bumps everytime because it might drag. the rack and pinion would give me more oil pan options because the drag link would not be in the way, so that is why I wanted r/p.
Re: new oil system or rack and pinion [Re: blindboyscuda] #1642634
07/12/14 09:27 PM
07/12/14 09:27 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
It would be Much easier to change the pan out then convert to a R/P and do Both.
