Re: Lowering a Cordoba
[Re: Diplomatt]
#163388
12/06/08 05:49 PM
12/06/08 05:49 PM
Posts: 451 Iowa
73ChargerSE440
Iowa
Someone help me if I am wrong on the J-body but do they have the torsion bar like the 75-79 dobas I thought you could crack on the torsion bar.
AB
67 Ply. Belvedere II 2dr Hardtop
73 Dodge Charger SE 440+6 727 Dana 60 4.10
78 Chrysler Cordoba 400-4 727 9 1/4 3.21
1999 Dodge Diesel 2500 QuadCab Longbox
2004 Dodge Durango HEMI Limited
[Re: Diplomatt]
#163391
12/06/08 08:08 PM
12/06/08 08:08 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Spring rates are built into the spring, short of physically modifying the spring you will not change the rate. What you will do is lessen the preload and you will hit the bump stops more often. Fatman Fabrication makes a drop spindle that will fit this application. http://www.fatmanfab.com/catalogpage.php?page=17Very last part on the page is the one that fits your application.
[Re: Supercuda]
#163392
12/06/08 09:10 PM
12/06/08 09:10 PM
Posts: 975 Page AZ
Diplomatt
Rodney Dangerfield Jr.
Page AZ
[Re: Diplomatt]
#163393
12/07/08 06:34 PM
12/07/08 06:34 PM
Posts: 451 Iowa
73ChargerSE440
Iowa
is the blocks in the rear an alternative to the shackle kits ?
[Re: 73ChargerSE440]
#163394
12/07/08 09:25 PM
12/07/08 09:25 PM
Supercuda
About to go away
About to go away
up yours
Be hard to lower a car with a shackle kit. There isn't much room to drop it, any less clearance and you will hit the frame with the spring. Shackle kits ae usually used to raise the rear, another bad idea along with blocks to lower it.
If you want to lower the rear you'd be better off raising the front spring mount up. On many Mopar you can swap the mounts side for side and flip them over to lower the car, you may have to oval the mounting holes a bit.
[Re: Magnumguy]
#163396
12/08/08 05:53 PM
12/08/08 05:53 PM
Posts: 451 Iowa
73ChargerSE440
Iowa
Sorry for the confusion, what's the other alternative to raising the rear besides the shackle kit
[Re: CYACOP]
#163398
12/08/08 11:17 PM
12/08/08 11:17 PM
Supercuda
About to go away
About to go away
up yours
Why do you want to raise the back? Going off road?
[Re: Supercuda]
#163399
12/08/08 11:22 PM
12/08/08 11:22 PM
moparpollack
Lil Herman
Lil Herman
85086
Raising the height of the rear end above the springs. Not raising the rear end up.
[Re: moparpollack]
#163400
12/09/08 09:15 AM
12/09/08 09:15 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
re-arched springs, or stiffer ones--the standard height 5 leaf HD springs raised the back end of my M body about 1-1.5" over my well worn stock 4 leaf springs.
[Re: Diplomatt]
#163401
12/09/08 10:52 AM
12/09/08 10:52 AM
Posts: 2,273 Greenville, South Carolina
BBLM23
1981 Mirada. I cranked down the bars and put in the solid mounts in the front. I put an 8 3/4 in and dumped the iso mounts in the back. I had 2 inch blocks in the back for a little while, too close to the stops. I ended up with 1 inch blocks. I had cop car wheels with a 65 series tire that was shorter than original. I can't remember the size.
Walter 1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph Racing Pro in street trim. 1981 Aries ARC 548 B1 8.88 at 147mph (footbraking) 1996 Ram 2500 V10 16.52 at 80mph 1981 Reliant 400
[Re: Supercuda]
#163403
12/13/08 02:58 PM
12/13/08 02:58 PM
Posts: 451 Iowa
73ChargerSE440
Iowa
10 yrs ago I added a shackle kit to the B-body Cordoba due to the sag, I knew at the time the shackle kits wasn't that safe, is my best bet now to get a new leaf spring set
AB
#163404
12/13/08 03:06 PM
12/13/08 03:06 PM
Posts: 451 Iowa
73ChargerSE440
Iowa
there was an article in Mopar Muscle DEC 1993 they did a J-body doba a white one, with 360/727 8¾ where they had done lowering. Anyone see that article ?
#163405
12/13/08 03:56 PM
12/13/08 03:56 PM
Posts: 451 Iowa
73ChargerSE440
Iowa
Assignment "J" Project Chrysler Cordoba
