Lowering a Cordoba #163387
12/06/08 05:41 PM
12/06/08 05:41 PM
Page AZ
Diplomatt Offline OP
Rodney Dangerfield Jr.
Page AZ
I was wondering if anyone here has ever lowered a J-Body Cordoba? I have a 1982, and thought it might be neat to do something different with it. I couldn't find anything online about lowering kits for the car.
Re: Lowering a Cordoba [Re: Diplomatt] #163388
12/06/08 05:49 PM
12/06/08 05:49 PM
Iowa
73ChargerSE440 Offline
Iowa
Someone help me if I am wrong on the J-body but do they have the torsion bar like the 75-79 dobas
I thought you could crack on the torsion bar.
AB
67 Ply. Belvedere II 2dr Hardtop 73 Dodge Charger SE 440+6 727 Dana 60 4.10 78 Chrysler Cordoba 400-4 727 9 1/4 3.21 1999 Dodge Diesel 2500 QuadCab Longbox 2004 Dodge Durango HEMI Limited
Re: Lowering a Cordoba [Re: 73ChargerSE440] #163389
12/06/08 05:54 PM
12/06/08 05:54 PM
Clinton Twp. Michigan
coronet1966d Offline
only thing you could do is crank down the T bars and put blocks in the back but your handling will suffer from the reduced spring rate from the torsion bars after you lower them
Re: Lowering a Cordoba [Re: coronet1966d] #163390
12/06/08 06:00 PM
12/06/08 06:00 PM
Page AZ
Page AZ
I was thinking about just cranking on the t-bars for the front, I'm not too worried about the handling of the car, if I lower it, it wouldn't be for performance... I want to do a "rat rod" type car with it.
With the back, would blocks be the only option?
Re: Lowering a Cordoba [Re: Diplomatt] #163391
12/06/08 08:08 PM
12/06/08 08:08 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Spring rates are built into the spring, short of physically modifying the spring you will not change the rate.
What you will do is lessen the preload and you will hit the bump stops more often. Fatman Fabrication makes a drop spindle that will fit this application.
http://www.fatmanfab.com/catalogpage.php?page=17
Very last part on the page is the one that fits your application.
Don't be the exception.
Re: Lowering a Cordoba [Re: Supercuda] #163392
12/06/08 09:10 PM
12/06/08 09:10 PM
Page AZ
Page AZ
Thanks for the link!
Re: Lowering a Cordoba [Re: Diplomatt] #163393
12/07/08 06:34 PM
12/07/08 06:34 PM
Iowa
Iowa
is the blocks in the rear an alternative to the shackle kits ?
Re: Lowering a Cordoba [Re: 73ChargerSE440] #163394
12/07/08 09:25 PM
12/07/08 09:25 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Be hard to lower a car with a shackle kit. There isn't much room to drop it, any less clearance and you will hit the frame with the spring. Shackle kits ae usually used to raise the rear, another bad idea along with blocks to lower it.
If you want to lower the rear you'd be better off raising the front spring mount up. On many Mopar you can swap the mounts side for side and flip them over to lower the car, you may have to oval the mounting holes a bit.
Re: Lowering a Cordoba [Re: Supercuda] #163395
12/07/08 10:36 PM
12/07/08 10:36 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
I'm glad you thought of them, I could not come up with that name. Fat man.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: Lowering a Cordoba [Re: Magnumguy] #163396
12/08/08 05:53 PM
12/08/08 05:53 PM
Iowa
Iowa
Sorry for the confusion, what's the other alternative to raising the rear besides the shackle kit
Re: Lowering a Cordoba [Re: 73ChargerSE440] #163397
12/08/08 06:17 PM
12/08/08 06:17 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
I wouldnt hack it up thats for sure.
Re: Lowering a Cordoba [Re: CYACOP] #163398
12/08/08 11:17 PM
12/08/08 11:17 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Why do you want to raise the back? Going off road?
Re: Lowering a Cordoba [Re: Supercuda] #163399
12/08/08 11:22 PM
12/08/08 11:22 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Raising the height of the rear end above the springs. Not raising the rear end up.
Re: Lowering a Cordoba [Re: moparpollack] #163400
12/09/08 09:15 AM
12/09/08 09:15 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
re-arched springs, or stiffer ones--the standard height 5 leaf HD springs raised the back end of my M body about 1-1.5" over my well worn stock 4 leaf springs.
2017 Grand Cherokee Overland
Re: Lowering a Cordoba [Re: Diplomatt] #163401
12/09/08 10:52 AM
12/09/08 10:52 AM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
1981 Mirada. I cranked down the bars and put in the solid mounts in the front. I put an 8 3/4 in and dumped the iso mounts in the back. I had 2 inch blocks in the back for a little while, too close to the stops. I ended up with 1 inch blocks. I had cop car wheels with a 65 series tire that was shorter than original. I can't remember the size.
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Re: Lowering a Cordoba [Re: moparpollack] #163402
12/09/08 11:01 PM
12/09/08 11:01 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
How would you do that with a shackle kit?
Re: Lowering a Cordoba [Re: Supercuda] #163403
12/13/08 02:58 PM
12/13/08 02:58 PM
Iowa
Iowa
10 yrs ago I added a shackle kit to the B-body Cordoba due to the sag, I knew at the time the shackle kits wasn't that safe, is my best bet now to get a new leaf spring set
AB
Re: Lowering a Cordoba [Re: 73ChargerSE440] #163404
12/13/08 03:06 PM
12/13/08 03:06 PM
Iowa
Iowa
there was an article in Mopar Muscle DEC 1993 they did a J-body doba a white one, with 360/727 8¾ where they had done lowering. Anyone see that article ?
Re: Lowering a Cordoba [Re: 73ChargerSE440] #163405
12/13/08 03:56 PM
12/13/08 03:56 PM
Iowa
Iowa
Assignment "J" Project Chrysler Cordoba
Re: Lowering a Cordoba [Re: 73ChargerSE440] #163406
12/13/08 07:59 PM
12/13/08 07:59 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
you can always do an axle under leaf spring conversion on the rear.
It will get you about 3.5" of lift, and the ride doesnt change much.
here is a Fury Sport with the axle flip.
