T-BAR TOOL #1627988
06/02/14 11:54 PM
06/02/14 11:54 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
Who sells them (at a reasonable price of course... )
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: T-BAR TOOL [Re: Magnumguy] #1627989
06/03/14 01:12 AM
06/03/14 01:12 AM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
Don't really need one, loosen the lca about 3/4, pry between the lca and kframe, it'll pop it right out.
-Daty
Re: T-BAR TOOL [Re: Daty Rogers] #1627990
06/03/14 12:42 PM
06/03/14 12:42 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
As Daty has eluded to, the tool isn't a necessity. I have done a lot of these in the garage. After you release all the torque applied to the bars but the adjuster in the LCA, it'll be ready to remove. Of course, the rear clip will need to be removed. I usually just separate the LCA/ball joint from the spindle via the two attach bolts. Then remove the 15/16" nut on the front of the LCA pin. I usually take a piece of wood and place it against the leading edge of the LCA and use a 5lb hammer. I don't whack it. I just use the momentum from the weight of the hammer and it is usually enough to push the LCA/torsion bar rearward. Done.....
Troy
Houston Mopar Connection Club
Re: T-BAR TOOL [Re: hemi68charger] #1627991
06/04/14 10:11 AM
06/04/14 10:11 AM
New Kent, Va.
bobbyb Offline
bobbyb  Offline
New Kent, Va.
All T-bars aren't created equal. On my 69 Roadrunner I had all the suspension out of the car except for the passenger T-bar. It would not budge. The car had rust issues so I'm thinking that didn't help. Anyway I had to beat the he!! out of it with a sledge hammer to get it out. Driver side came on out. American Muscle, and someone said there are some on ebay and at Mancini's.
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
Re: T-BAR TOOL [Re: Magnumguy] #1627992
06/04/14 11:32 AM
06/04/14 11:32 AM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
For the really stubborn ones I have always used a couple of 1" rope clamps clamped side by side.
Cheap and effective.
Master, again and still
Re: T-BAR TOOL [Re: DaveRS23] #1627993
06/04/14 11:43 AM
06/04/14 11:43 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The joy of cleaning out old dealerships !!
Re: T-BAR TOOL [Re: bobbyb] #1627994
06/04/14 12:13 PM
06/04/14 12:13 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Very true.
What this man said.
Sooner or later, you are going to run into some stubborn torsion bars in their removal, if you do enough of them.
Then that removal tool is indespensable, and you would wish you had one.
But for me, prying between the crossmember, and the LCA, with a big bry bar, works 90% of the time.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: T-BAR TOOL [Re: hemi71x] #1627995
06/04/14 07:51 PM
06/04/14 07:51 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
This works for me.
Re: T-BAR TOOL [Re: 5carguy] #1627996
06/05/14 01:02 AM
06/05/14 01:02 AM
S.E.Ohio
S.E.Ohio
Maybe I wasn't clear.
I need one for somebody, to give them. I don't need to remove a bar. Where can I buy one?
Re: T-BAR TOOL [Re: bobbyb] #1627997
06/05/14 09:28 AM
06/05/14 09:28 AM
New Kent, Va.
bobbyb Offline
bobbyb  Offline
New Kent, Va.
Re: T-BAR TOOL [Re: bobbyb] #1627998
06/05/14 09:40 AM
06/05/14 09:40 AM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
I have them available in my online store, Made from 1"X 1" steel with a knurled handle it uses 2 3/8 16 grade 8 bolts for the clamping force. http://www.custommachinecomponents.com/shopdisplayproducts.asp?page=3&id=8
Re: T-BAR TOOL [Re: 5carguy] #1627999
06/05/14 11:07 AM
06/05/14 11:07 AM
STL
cdstl Offline
cdstl  Offline
STL
This works for me.
I don't remember if I bought mine from Mancini or not but it got pretty beat up removing my T-bars just like the one in the picture. They were in really tight.
http://chucker54.stores.yahoo.net/frsuto.html
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: T-BAR TOOL [Re: johnscudashop] #1628000
06/05/14 11:08 AM
06/05/14 11:08 AM
NO RUST IN AZ!!!
azmopar Offline
azmopar  Offline
NO RUST IN AZ!!!
this is the one I have works good especially on stuck t bars
70 Challenger Convertible 340 six pak CLONE?
70 Duster real FM3 car
65 Dart Charger FOR SALE
#NONIKESEVER
A Real man aint afraid to drive PINK!!!!
67 Plymouth Valiant PILOT CAR 273 Commando 4 spd
Re: T-BAR TOOL [Re: azmopar] #1628001
06/05/14 03:05 PM
06/05/14 03:05 PM
SE PA
MattMPA Offline
MattMPA  Offline
SE PA
An old Chrysler mechanic gave me a tip over 20 years ago for removing torsion bars. Get a big bolt....a BIG bolt. Just small enough to fit through the rear of the t-bar mount under the floor.
Put the bolt against the t-bar and give it a few sturdy hits. Yiu are "driving" it towards the front of the car. This somehow releases the t-bar and you can remove it easily without tools. Worked for me many times..
Re: T-BAR TOOL [Re: azmopar] #1628002
06/05/14 03:40 PM
06/05/14 03:40 PM
Oakville, Ontario, Canada
CDN72SE Offline
CDN72SE  Offline
X2 bought the same one, worked great on my stuck bar.
Re: T-BAR TOOL [Re: CDN72SE] #1628003
06/05/14 05:39 PM
06/05/14 05:39 PM
S.E.Ohio
S.E.Ohio
Thanks folks!!!
