Re: T-BAR TOOL
[Re: Daty Rogers]
#1627990
06/03/14 12:42 PM
06/03/14 12:42 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
As Daty has eluded to, the tool isn't a necessity. I have done a lot of these in the garage. After you release all the torque applied to the bars but the adjuster in the LCA, it'll be ready to remove. Of course, the rear clip will need to be removed. I usually just separate the LCA/ball joint from the spindle via the two attach bolts. Then remove the 15/16" nut on the front of the LCA pin. I usually take a piece of wood and place it against the leading edge of the LCA and use a 5lb hammer. I don't whack it. I just use the momentum from the weight of the hammer and it is usually enough to push the LCA/torsion bar rearward. Done.....
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: T-BAR TOOL
[Re: hemi68charger]
#1627991
06/04/14 10:11 AM
06/04/14 10:11 AM
Posts: 1,290 New Kent, Va.
bobbyb
New Kent, Va.
All T-bars aren't created equal. On my 69 Roadrunner I had all the suspension out of the car except for the passenger T-bar. It would not budge. The car had rust issues so I'm thinking that didn't help. Anyway I had to beat the he!! out of it with a sledge hammer to get it out. Driver side came on out. American Muscle, and someone said there are some on ebay and at Mancini's.
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
Re: T-BAR TOOL
[Re: Magnumguy]
#1627992
06/04/14 11:32 AM
06/04/14 11:32 AM
Posts: 12,293 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
For the really stubborn ones I have always used a couple of 1" rope clamps clamped side by side.
Cheap and effective.
Master, again and still
Re: T-BAR TOOL
[Re: bobbyb]
#1627994
06/04/14 12:13 PM
06/04/14 12:13 PM
Posts: 5,366 Rancho Cordova, California (Sa...
hemi71x
Very true. What this man said. Sooner or later, you are going to run into some stubborn torsion bars in their removal, if you do enough of them. Then that removal tool is indespensable, and you would wish you had one. But for me, prying between the crossmember, and the LCA, with a big bry bar, works 90% of the time.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: T-BAR TOOL
[Re: azmopar]
#1628001
06/05/14 03:05 PM
06/05/14 03:05 PM
Posts: 101 SE PA
MattMPA
SE PA
An old Chrysler mechanic gave me a tip over 20 years ago for removing torsion bars. Get a big bolt....a BIG bolt. Just small enough to fit through the rear of the t-bar mount under the floor.
Put the bolt against the t-bar and give it a few sturdy hits. Yiu are "driving" it towards the front of the car. This somehow releases the t-bar and you can remove it easily without tools. Worked for me many times..
