AM/FM Radio ID #1622745
05/20/14 09:04 PM
05/20/14 09:04 PM
Overpriced Housing Central
RobX4406 Offline OP
RobX4406  Offline OP
I pulled this AM/FM radio out of a 70 Swinger 340 car that I have. The car came with a AM radio, so someone swapped this in. None of the wires appear to be cut or mangled. All of the stickers are so faded they can't be read or gone.
Rob
Re: AM/FM Radio ID [Re: RobX4406] #1622746
05/20/14 09:35 PM
05/20/14 09:35 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Those look like the brackets for a 68-69 Barracuda radio, but they usually say PLYMOUTH SOLID STATE. I guess they would be the same for any ralley dash.
JB Rhinehart, Realist
A-Body's RULE!
Re: AM/FM Radio ID [Re: RobX4406] #1622747
05/22/14 01:53 PM
05/22/14 01:53 PM
RobX4406 Offline OP
RobX4406  Offline OP
Anybody have a positive ID for this thing?
Lewis?
Re: AM/FM Radio ID [Re: RobX4406] #1622748
05/22/14 02:01 PM
05/22/14 02:01 PM
Alberta, Canada
K
krisiesmopes Offline
K
Alberta, Canada
I would say 68 and 69 B body, with a 69 Barracuda faceplate mounted to the front.
Re: AM/FM Radio ID [Re: RobX4406] #1622749
05/22/14 02:03 PM
05/22/14 02:03 PM
Northern BC
Canucklehead Offline
Northern BC
Definitely 70 340 Swinger, one year only, Dodge only, rally dash only. Never figured out why they put Chrysler solid state instead of Dart solid state like the previous years.
Re: AM/FM Radio ID [Re: Canucklehead] #1622750
05/22/14 02:08 PM
05/22/14 02:08 PM
WI
FrobCano Offline
FrobCano  Offline
WI
I second the Swinger ('70) answer. Let me see if I can get my friend to post a similar pic from his.
Re: AM/FM Radio ID [Re: FrobCano] #1622751
05/22/14 04:12 PM
05/22/14 04:12 PM
Alabama
BigMoneyLewis Offline
Alabama
The black plastic pushbuttons tell us it's a 68-9 B body radio that someone has swapped the 68-9 Barracuda chrome bezel and lense on to.
The other obvious sign will be the location of the mounting stud .
It will be on the back of the radio for the B body, and on the bottom cover plate
for the A bodies , and rallye dash and non rallye dash A bodies used two diffrent locations , note the DV(Dart Valiant) and B(Barracuda) stamped in to the bottom .
Had it been a correct 1970 Duster 340/Dart Swinger 340 it would have had the same fat chrome push buttons as found on the 68-9 Barracuda and Valiant. The thin chrome push buttons are unique to 68-9 Dart .
I see alot of these "Frankenstein radios" where someone has taken 2 and somtimes 3 diffrent radios and tried to make something that fit their application.
Greg
gregward@mchsi.com phone 256-852-0955
Re: AM/FM Radio ID [Re: BigMoneyLewis] #1622752
05/22/14 04:33 PM
05/22/14 04:33 PM
RobX4406 Offline OP
RobX4406  Offline OP
It has DV and B stamped in the bottom plate and has a bottom mount on it.
So it is an A body?
The buttons can be swapped out?
Thanks for the help.
Re: AM/FM Radio ID [Re: BigMoneyLewis] #1622753
05/22/14 05:14 PM
05/22/14 05:14 PM
Northern BC
Northern BC
Greg
Wouldn't it make more sense that the buttons were changed? The chrome didn't seem to last.
Re: AM/FM Radio ID [Re: Canucklehead] #1622754
05/22/14 06:57 PM
05/22/14 06:57 PM
Alabama
Alabama
Is their a mounting stud on the back as well ? The bottom cover plate can easily be swapped between A and B body . As far as the buttons, they can be swapped as well, but most people do not know how to do it without damaging something. The bezel/ lense swap is simple and would be my guess.
If their is a stud on the back of the radio, or evidence where the stud was , then It was a B body that someone swapped the chrome bezel, lense and bottom cover plate from an A body rallye dash car .
If their is no stud on back , or evidence where it was, then it would appear to be an A body rallye dash radio that someone swapped 68-9 B body black pushbuttons on to.
Greg
Re: AM/FM Radio ID [Re: BigMoneyLewis] #1622755
05/22/14 08:06 PM
05/22/14 08:06 PM
RobX4406 Offline OP
RobX4406  Offline OP
Greg
Doesn't appear to have a stud on rear.
Thanks for the info.
