Re: AM/FM Radio ID
[Re: RobX4406]
#1622746
05/20/14 09:35 PM
05/20/14 09:35 PM
Posts: 43,517 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Those look like the brackets for a 68-69 Barracuda radio, but they usually say PLYMOUTH SOLID STATE. I guess they would be the same for any ralley dash.
JB Rhinehart, Realist
A-Body's RULE!
Re: AM/FM Radio ID
[Re: BigMoneyLewis]
#1622753
05/22/14 05:14 PM
05/22/14 05:14 PM
Posts: 327 Northern BC
Canucklehead
Northern BC
The black plastic pushbuttons tell us it's a 68-9 B body radio that someone has swapped the 68-9 Barracuda chrome bezel and lense on to. The other obvious sign will be the location of the mounting stud . It will be on the back of the radio for the B body, and on the bottom cover plate for the A bodies , and rallye dash and non rallye dash A bodies used two diffrent locations , note the DV(Dart Valiant) and B(Barracuda) stamped in to the bottom . Had it been a correct 1970 Duster 340/Dart Swinger 340 it would have had the same fat chrome push buttons as found on the 68-9 Barracuda and Valiant. The thin chrome push buttons are unique to 68-9 Dart . I see alot of these "Frankenstein radios" where someone has taken 2 and somtimes 3 diffrent radios and tried to make something that fit their application.
Greg
Wouldn't it make more sense that the buttons were changed? The chrome didn't seem to last.
Re: AM/FM Radio ID
[Re: BigMoneyLewis]
#1622755
05/22/14 08:06 PM
05/22/14 08:06 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
Is their a mounting stud on the back as well ? The bottom cover plate can easily be swapped between A and B body . As far as the buttons, they can be swapped as well, but most people do not know how to do it without damaging something. The bezel/ lense swap is simple and would be my guess. If their is a stud on the back of the radio, or evidence where the stud was , then It was a B body that someone swapped the chrome bezel, lense and bottom cover plate from an A body rallye dash car . If their is no stud on back , or evidence where it was, then it would appear to be an A body rallye dash radio that someone swapped 68-9 B body black pushbuttons on to.
Greg
Doesn't appear to have a stud on rear.
Thanks for the info.
