Source for 130 tooth 10.5 bell flywheel? #1619625
05/13/14 01:23 AM
05/13/14 01:23 AM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
For a mild street/strip car what is the best and most economical choice for a 10.5/130 flywheel? This is new territory to me and these prices I've seen are scary
Re: Source for 130 tooth 10.5 bell flywheel? [Re: SLOW67] #1619626
05/13/14 02:20 AM
05/13/14 02:20 AM
in a chair
mopartony Offline
mopartony  Offline
in a chair
Who have you looked at?
I am going to Meziere. Pricey but the only show in town for what I need.
Re: Source for 130 tooth 10.5 bell flywheel? [Re: mopartony] #1619627
05/13/14 02:59 AM
05/13/14 02:59 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I bought mine from American Powertrain when they had a 25% off sale. Summit sells them at pretty much the same price Brewer's sells McLeod's for.
Mopar to the bone!!!
Re: Source for 130 tooth 10.5 bell flywheel? [Re: SLOW67] #1619628
05/13/14 12:03 PM
05/13/14 12:03 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
Buy a BILLET wheel if you are not running a blowshield ... How much are you FEET worth ?
Re: Source for 130 tooth 10.5 bell flywheel? [Re: JohnRR] #1619629
05/13/14 04:44 PM
05/13/14 04:44 PM
dogdays Offline
dogdays  Offline
440Source has steel ones for abut $200.
R.
Re: Source for 130 tooth 10.5 bell flywheel? [Re: SLOW67] #1619630
05/13/14 08:19 PM
05/13/14 08:19 PM
AndyF Offline
AndyF  Offline
Flywheels are fairly inexpensive unless you're looking for something custom. PRW has nice flywheels that don't cost a ton. I use PRW flywheels on all of the dyno engines.
Re: Source for 130 tooth 10.5 bell flywheel? [Re: AndyF] #1619631
05/13/14 08:53 PM
05/13/14 08:53 PM
dogdays Offline
dogdays  Offline
I wish their doggone website would show Mopar wheels.
R.
Re: Source for 130 tooth 10.5 bell flywheel? [Re: dogdays] #1619632
05/13/14 11:33 PM
05/13/14 11:33 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
R.
I used one of those once, it not only had the ring gear teeth off enough I had to shim the starter so it could disengage, after 1500 miles it looked like a worn out brake rotor.POS
http://americanpowertrain.com/i-8426648-...al-balance.html
Buyer beware though, it states "SFI Quality" not SFI Approved. A McLeod is probably $50-75 more and is SFI Approved FWIW.
Re: Source for 130 tooth 10.5 bell flywheel? [Re: 72Swinger] #1619633
05/14/14 12:43 PM
05/14/14 12:43 PM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
R.
Do you have a picture of the flywheel? maybe the problem was the clutch? A flywheel isn't a sophisticated device..I doubt that a billet flywheel will wear that quickly..
The 440source flywheels look like exact copies of the McLeod wheels..
Re: Source for 130 tooth 10.5 bell flywheel? [Re: AndyF] #1619634
05/14/14 12:45 PM
05/14/14 12:45 PM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
They don't seem to make Mopar flywheels...
Re: Source for 130 tooth 10.5 bell flywheel? [Re: DGS] #1619635
05/14/14 01:57 PM
05/14/14 01:57 PM
dogdays Offline
dogdays  Offline
Andy has said this before, he usually knows what he's talking about. I bet they haven't updated their website in years. I also bet that they make the flywheels for 440Source.
The absolute cheapest 10.5" 130 tooth flywheel is sitting on a 318 at the junkyard.
R.
Re: Source for 130 tooth 10.5 bell flywheel? [Re: DGS] #1619636
05/14/14 08:34 PM
05/14/14 08:34 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
R.
I really dont think the flywheel they sell is Billet. I sold the pressure plate from that setup and it was in near perfect as new condition.
Re: Source for 130 tooth 10.5 bell flywheel? [Re: 72Swinger] #1619637
05/14/14 10:00 PM
05/14/14 10:00 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I bought my Billet 130 tooth from Bob Mozzolini Racing.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Source for 130 tooth 10.5 bell flywheel? [Re: 72Swinger] #1619638
05/15/14 05:49 AM
05/15/14 05:49 AM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
R.
That's interesting. Thanks for the heads up. Maybe they changed the flywheel because when they first came out they were only $99, then $149 and now $199. 440source clearly state on their website that the flywheels are billet CNC ground steel wheels.. I don't think that they would blatantly lie about their product. Too much risk to get sued..
Re: Source for 130 tooth 10.5 bell flywheel? [Re: DGS] #1619639
05/15/14 11:01 AM
05/15/14 11:01 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I have a $100 flywheel off of ebay, on the convertible, never had an issue since I installed it back in 2008. 511ci motor, mini starter, Centerforce Dual Friction clutch.
Re: Source for 130 tooth 10.5 bell flywheel? [Re: Defbob] #1619640
05/15/14 12:58 PM
05/15/14 12:58 PM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
Well I bought one from 440 source so I guess we will see. Now I'm on the hunt for a good clutch that doesn't kill the wallet. I think I've settled on a hays 10.5 street strip unit but I haven't pulled the trigger yet
Re: Source for 130 tooth 10.5 bell flywheel? [Re: Defbob] #1619641
05/15/14 01:16 PM
05/15/14 01:16 PM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
I'm about to use an ebay flywheel myself, looks just like the one 440 source sells, two pressure plate patterns and a bolt on weight for external balance.
Has part number FW-1900 on the engine side.
I bought it to use on a '73 400 so I'm hoping the balance is right
Re: Source for 130 tooth 10.5 bell flywheel? [Re: Diplomat440] #1619642
05/15/14 01:53 PM
05/15/14 01:53 PM
dogdays Offline
dogdays  Offline
Think about it, any steel flywheel is billet. What else would it be? All billet means is that it was machined from a larger piece of material. Even if it was machined from a 1" thick plate it would still be billet.
I guess could be cast, but why? It'd still have to be machined, would probably cost about the same.....
A couple of years ago when AndyF first started talking about PRW billet wheels he too mentioned a price of $100. They don't cost that anymore. I have a feeling the "introductory price" was to get the market opened up, now the y are making some money on the wheels. BTW, that's the American way, not a bad thing.
R.
Re: Source for 130 tooth 10.5 bell flywheel? [Re: DGS] #1619643
05/17/14 01:09 AM
05/17/14 01:09 AM
AndyF Offline
AndyF  Offline
The PRW flywheel box that I have on the shelf is #1642600. It is the 8 bolt version. I also have a 6 bolt version but I think I tossed the box out since I don't see it in the clutch/flywheel section of my shop.
