1970 Challenger tail lamp housing finish #1617399
05/07/14 12:44 PM
05/07/14 12:44 PM
New York
Mopucky Offline OP
Mopucky  Offline OP
New York
What is the correct O.E. finish for this housing as seen in trunk? Thanks!
Re: 1970 Challenger tail lamp housing finish [Re: Mopucky] #1617400
05/07/14 02:16 PM
05/07/14 02:16 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Natural smooth finish injected casted pot metal. Grey looking color.
Re: 1970 Challenger tail lamp housing finish [Re: autoxcuda] #1617401
05/07/14 02:35 PM
05/07/14 02:35 PM
New York
Mopucky Offline OP
Mopucky  Offline OP
New York
Thanks! Any easy way of getting it back without abrasives?
Re: 1970 Challenger tail lamp housing finish [Re: Mopucky] #1617402
05/07/14 03:15 PM
05/07/14 03:15 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Mine are perfect but really stained appearance. I bought a harbor freight portable soda blaster. Thinking to use it for the job.
Opinions before I mess up?
Re: 1970 Challenger tail lamp housing finish [Re: Sxrxrnr] #1617403
05/18/14 09:49 PM
05/18/14 09:49 PM
WNY
slimert Offline
slimert  Offline
WNY
Mine had some paint overspray, it cleaned up nicely with lacquer thinner and 0000 steel wool. Be sure to tape off the light bulb hole to keep the inside reflective silver from getting messed up.
Re: 1970 Challenger tail lamp housing finish [Re: slimert] #1617404
05/18/14 11:04 PM
05/18/14 11:04 PM
Oakville.ON,Canada
hemi_rtdave Offline
hemi_rtdave  Offline
Oakville.ON,Canada
Please correct me if I am wrong but...
My understanding is that the entire assembly was together when the blackout was applied to the top leading edge of the chrome, thus leaving overspray on the housing. I have seen cars done this way.
Anyone else?
Re: 1970 Challenger tail lamp housing finish [Re: hemi_rtdave] #1617405
05/19/14 09:19 AM
05/19/14 09:19 AM
MA
steve70 Offline
steve70  Offline
MA
Anyone else?
You are correct. Here's a picture from an original T/A
1970 Challenger T/A 4 speed
Re: 1970 Challenger tail lamp housing finish [Re: steve70] #1617406
05/19/14 06:17 PM
05/19/14 06:17 PM
california
Mr D21 Offline
Mr D21  Offline
california
Blacked out as an assembly ?? I have an NOS set of Bezels and they have the black out already applied, so,,, ????
Any other opinions about that ?
Re: 1970 Challenger tail lamp housing finish [Re: Sxrxrnr] #1617407
06/29/14 07:09 PM
06/29/14 07:09 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
I had noted in earlier post to this thread that I was going to try soda blasting to clean mine. Instead I decided to try my recently acquired HF bead blaster using glass beads as soda blasting would be quite messy.
I did a bit on the bottom side in the event that did not come out well. Looked ok, so then completely did all 4 of them.
They came out perfect and as new.
Took some before and after photos with iPhone, but too high resolution( why does iPhone not let you turn this down a bit to save memory and permit easier uploading is beyond me) to upload, so will have to cut back size somehow.
Also must learn how to upload multiple photos in a single posting.
Get this sorted out and will post outcome photos.
Re: 1970 Challenger tail lamp housing finish [Re: Mr D21] #1617408
06/29/14 10:33 PM
06/29/14 10:33 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
That's an original paint 30K mile car. It is what it is. Exactly where in assembly it got there is the debate. Being a T/A it's got rear blackout, but there was blackout under the tailight housings put on prior to installation.
Do you have pics that show differently from other/your low milage survivor original paint 70 Challengers?
blacked out before tail light installed. This picture is of the same car Steve70 now owns and that those tailights he posted above came out of.
Re: 1970 Challenger tail lamp housing finish [Re: Sxrxrnr] #1617409
06/29/14 10:35 PM
06/29/14 10:35 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Did you run the glass bead blaster at lower than normal pressure?
Re: 1970 Challenger tail lamp housing finish [Re: autoxcuda] #1617410
06/29/14 10:57 PM
06/29/14 10:57 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Full bore. Ended job with proper stock texture,,,factory if you look at yours is quite pebbly,,and color is spot on. Did not remove any factory finish,,,likely just raw pot metal anyhow. Not shiny or some such as spraying with a rattle can. Could not be more pleased. Again used glass beads from HF, not sand.
