Re: 1970 Challenger tail lamp housing finish
[Re: Mopucky]
#1617400
05/07/14 02:16 PM
05/07/14 02:16 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
What is the correct O.E. finish for this housing as seen in trunk? Thanks!
Natural smooth finish injected casted pot metal. Grey looking color.
[Re: Sxrxrnr]
#1617407
06/29/14 07:09 PM
06/29/14 07:09 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
I had noted in earlier post to this thread that I was going to try soda blasting to clean mine. Instead I decided to try my recently acquired HF bead blaster using glass beads as soda blasting would be quite messy.
I did a bit on the bottom side in the event that did not come out well. Looked ok, so then completely did all 4 of them.
They came out perfect and as new.
Took some before and after photos with iPhone, but too high resolution( why does iPhone not let you turn this down a bit to save memory and permit easier uploading is beyond me) to upload, so will have to cut back size somehow.
Also must learn how to upload multiple photos in a single posting.
Get this sorted out and will post outcome photos.
[Re: Sxrxrnr]
#1617409
06/29/14 10:35 PM
06/29/14 10:35 PM
autoxcuda
So Cal
Did you run the glass bead blaster at lower than normal pressure?
[Re: autoxcuda]
#1617410
06/29/14 10:57 PM
06/29/14 10:57 PM
Sxrxrnr
Northern Calyfornua
Full bore. Ended job with proper stock texture,,,factory if you look at yours is quite pebbly,,and color is spot on. Did not remove any factory finish,,,likely just raw pot metal anyhow. Not shiny or some such as spraying with a rattle can. Could not be more pleased. Again used glass beads from HF, not sand.
