Cam grind number? #1612923
04/27/14 10:46 PM
04/27/14 10:46 PM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
I got a mystery cam from a friend that he pulled out of a built 360. I has the number 18z002 and the letters MP on the end. Is there anyway of knowing what it is?
Re: Cam grind number? [Re: SLOW67] #1612924
04/29/14 12:58 AM
04/29/14 12:58 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
No info on the numbers> But you can take a set of calipers and measure the base circle of the cam, then measure the total base with the entire lobes height. Subtract the base from the total and it will give you the lobe lift. Multiply that by 1.5 rocker ratio and that will give approximate lift. That will give you a idea of what you have. Measure it and post the numbers.
Re: Cam grind number? [Re: Sport440] #1612925
04/29/14 11:44 PM
04/29/14 11:44 PM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
Got 1.570 on the lobe and 1.25 on the base circle so on a 1.5 ratio that should be around .480 right? Is there any way to check LSA?
Re: Cam grind number? [Re: SLOW67] #1612926
04/30/14 12:57 AM
04/30/14 12:57 AM
Cab_Burge Online work
Cab_Burge  Online Work
Nope, unless you consider having it ran on a Cam Doctor for all the specs.
Re: Cam grind number? [Re: Cab_Burge] #1612927
04/30/14 01:21 AM
04/30/14 01:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Well he could put it in a block with a crank and measure
the lobe spread
Re: Cam grind number? [Re: SLOW67] #1612928
04/30/14 01:21 AM
04/30/14 01:21 AM
Chester, VA
tobnHisglory Offline
Chester, VA
You can check the specs by installing it temporally in a spare block and taking measurements. Hook up a degree wheel on the crank and a dial indicator on first the intake lifter and then the exhaust lifter on the same cylinder. Note the degree for max lift on each lobe and subtract to find the lsa. You can also check over all duration and at .050 lift.
Good luck!
-Reggie
tobnHisglory2000@aol.com
Former Mopars: 73 Charger - 440/727, 68 D200 Camper Special 383/727, 67 Satellite, 71 Superbee, 73 RoadRunner,2009 Ram Quad Cab Hemi 4x4
Current Mopars: 2005 Ram Quad Cab Hemi 4x4, 73 Cuda FE5 318 manual
Re: Cam grind number? [Re: MR_P_BODY] #1612929
04/30/14 01:25 AM
04/30/14 01:25 AM
Chester, VA
Chester, VA
Mr P Body beat me to the punch. Missed it by that much...
-Reggie
Re: Cam grind number? [Re: SLOW67] #1612930
04/30/14 01:57 AM
04/30/14 01:57 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Thats enough info for me. Its got to be a MP 484 cam. 108 LSA
Re: Cam grind number? [Re: MR_P_BODY] #1612931
04/30/14 03:18 PM
04/30/14 03:18 PM
the lobe spread
I thought I read "easy way" to check LSA
