Re: Cam grind number?
[Re: SLOW67]
#1612924
04/29/14 12:58 AM
04/29/14 12:58 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
No info on the numbers> But you can take a set of calipers and measure the base circle of the cam, then measure the total base with the entire lobes height. Subtract the base from the total and it will give you the lobe lift. Multiply that by 1.5 rocker ratio and that will give approximate lift. That will give you a idea of what you have. Measure it and post the numbers.
[Re: Cab_Burge]
#1612927
04/30/14 01:21 AM
04/30/14 01:21 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Is there any way to check LSA?
Nope, unless you consider having it ran on a Cam Doctor for all the specs.
Well he could put it in a block with a crank and measure the lobe spread
[Re: SLOW67]
#1612928
04/30/14 01:21 AM
04/30/14 01:21 AM
Posts: 198 Chester, VA
tobnHisglory
Chester, VA
You can check the specs by installing it temporally in a spare block and taking measurements. Hook up a degree wheel on the crank and a dial indicator on first the intake lifter and then the exhaust lifter on the same cylinder. Note the degree for max lift on each lobe and subtract to find the lsa. You can also check over all duration and at .050 lift. Good luck!
-Reggie tobnHisglory2000@aol.com Former Mopars: 73 Charger - 440/727, 68 D200 Camper Special 383/727, 67 Satellite, 71 Superbee, 73 RoadRunner,2009 Ram Quad Cab Hemi 4x4 Current Mopars: 2005 Ram Quad Cab Hemi 4x4, 73 Cuda FE5 318 manual
[Re: MR_P_BODY]
#1612929
04/30/14 01:25 AM
04/30/14 01:25 AM
tobnHisglory
Chester, VA
Mr P Body beat me to the punch. Missed it by that much...
