Page 4 of 7 1 2 3 4 5 6 7
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609666
04/19/14 11:04 PM
04/19/14 11:04 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Some parts like the various hoses, fuel filter, fuel line clamps, etc. are the best/most accurate reproduction parts available, that said, there are some subtle differences as compared to NOS with most of them.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609667
04/19/14 11:09 PM
04/19/14 11:09 PM
New York
Mopucky Offline OP
Mopucky  Offline OP
New York
SCOTT!!! WOW! This is EXACTLY what I needed to see! You did my Thermoquad two years ago and it was too pretty to put on my old engine so I'm going through it now. I can only hope my engine comes out as nice as yours!
Thanks for taking the time to post all of those for me!
Re: 1971 340 Cuda Engine Paint Details [Re: Mopucky] #1609668
04/19/14 11:37 PM
04/19/14 11:37 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
That's a sexy engine! I can't wait to get mine assembled and painted. Scott, did you purchase date coded spark plug wires or did you stencil your own?
I know I've read that the plastic wire holders were unpainted, but my 1970 Duster 340 wire holders have traces of orange paint on them.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609669
04/19/14 11:48 PM
04/19/14 11:48 PM
Kirkland, Washington
Pacnorthcuda Offline
That's really stunning Scott! I am curious, what combination of parts dictated a power steering cooler on an A body? Axle package?
Re: 1971 340 Cuda Engine Paint Details [Re: FJR doc] #1609670
04/19/14 11:52 PM
04/19/14 11:52 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The wires you see in those pics are NOS originals (good luck finding any with good date codes!) The reproductions by Lectric Limited are the best I've seen, not 100% exact, but 98% or so which will make most happy.
Painted wire looms were the norm on blue painted engines (After April or so of 1971 ), but not on orange engines, yes exceptions happened but based on the larger number of unpainted originals I've seen my money would be on that yours have had some touch up paint overspray at some time in the past and are not original, but as I said, it's possible.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609671
04/19/14 11:53 PM
04/19/14 11:53 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Axel package cars should have had a cooler (3.55 or 3.91 gears)
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609672
04/20/14 12:08 AM
04/20/14 12:08 AM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
Do you know who sells Electric Limited wires? I did a Google search and didn't find any info?
Kevin
Re: 1971 340 Cuda Engine Paint Details [Re: FJR doc] #1609673
04/20/14 12:10 AM
04/20/14 12:10 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Layson's carries them as do several other vendors Lectric Limited
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609674
04/20/14 04:15 AM
04/20/14 04:15 AM
Sweden
71redcuda Offline
71redcuda  Offline
Sweden
Scott,really great pic and information.
Re: 1971 340 Cuda Engine Paint Details [Re: 71redcuda] #1609675
04/20/14 09:40 AM
04/20/14 09:40 AM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
Is the engine paint from Frank Badalsan? No hardener or primer? The sheen looks dead on to my block.
Kevin
Re: 1971 340 Cuda Engine Paint Details [Re: FJR doc] #1609676
04/20/14 12:10 PM
04/20/14 12:10 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes that is Frank Badelson's paint, right out of the can (thinned as recommended in his instructions) with no additives.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609677
04/20/14 01:37 PM
04/20/14 01:37 PM
New York
Mopucky Offline OP
Mopucky  Offline OP
New York
Scott what did you thin it with? I bought it from Frank and didn't get any instructions.
Also Would you suspect that all water pump and timing cover bolts were painted and then backed out and re-attached for A/C components as well?
Re: 1971 340 Cuda Engine Paint Details [Re: Mopucky] #1609678
04/20/14 02:00 PM
04/20/14 02:00 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I don't remember the mix off hand but I added some enamel reducer to thin it up a little, it is pretty thick out of the can. I think you could spray it right out of the can with no issues, it just flows a little better with a bit of reducer added.
On the A/C bolts, I haven't seen a survivor with air to confirm so I can't say. Bolts that pass through the water pump housing were likely painted and reused IF they were long enough to work as retainers for the A/C components, if not new longer bolts would have been installed with the A/C parts.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609679
04/20/14 03:45 PM
04/20/14 03:45 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
Troy just did a fairly unmolested 71 A/C 340 auto N95 car. He may have pics and remember to corroborate other findings.
Re: 1971 340 Cuda Engine Paint Details [Re: autoxcuda] #1609680
04/20/14 07:20 PM
04/20/14 07:20 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Were all the power steering pump pulleys sloted?Was the solid pulley correct too? TIA
Re: 1971 340 Cuda Engine Paint Details [Re: 5carguy] #1609681
04/20/14 08:03 PM
04/20/14 08:03 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
On A-bodies the slotted stye is all I've seen, B-E body cars I've seen had the solid pulley. I'm not sure how much if any cross over there was.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609682
04/20/14 08:10 PM
04/20/14 08:10 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Great information.Thanks
Re: 1971 340 Cuda Engine Paint Details [Re: 5carguy] #1609683
04/20/14 08:18 PM
04/20/14 08:18 PM
New York
Mopucky Offline OP
Mopucky  Offline OP
New York
My pulley is solid
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609684
04/20/14 09:46 PM
04/20/14 09:46 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
I dont know if you remember the unmolested 71 340 hemi orange duster I had, but that had a solid pulley..
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: 1971 340 Cuda Engine Paint Details [Re: mopars_1] #1609685
04/20/14 11:23 PM
04/20/14 11:23 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I don't recall that car, are you sure the pump was original? Did it have a cooler? Do you have any pics?
