727 Wont shift into forward gears #1603188
04/04/14 07:57 PM
04/04/14 07:57 PM
Indy
moparman89 Offline OP
Indy
Installed a Cheetah rev man valve body in my 727. I attempted to hook up the shifter linkage when I discovered that it will not shift into the forward gears. Even with the linkage unhooked it wont shift.
Dropped the pan and removed valve body, valve body shifts fine on the bench. What gives?
School of Automotive Machinists Racing
Re: 727 Wont shift into forward gears [Re: moparman89] #1603189
04/04/14 08:10 PM
04/04/14 08:10 PM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
the neutral switch could be interfering with the vb shift pointer?
Re: 727 Wont shift into forward gears [Re: moparman89] #1603190
04/04/14 08:37 PM
04/04/14 08:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
When you fed the Park rod into the tail it might have misaligned with the hole, try it again and be sure the rod moves freely.
Re: 727 Wont shift into forward gears [Re: moparman89] #1603191
04/04/14 09:37 PM
04/04/14 09:37 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
Check the pinch bolt on the shift lever. It maybe slipping on the manual lever assy.
Re: 727 Wont shift into forward gears [Re: rickraw] #1603192
04/04/14 09:41 PM
04/04/14 09:41 PM
Indy
Indy
Check the safety switch, not it. Took the parking rod off and reinstalled, works great.
Any tips for installing the parking rod, obviously I didnt get it right the first time.
Re: 727 Wont shift into forward gears [Re: moparman89] #1603193
04/04/14 10:17 PM
04/04/14 10:17 PM
Monroeville Ohio
Traven Offline
Traven  Offline
Monroeville Ohio
Check the rod and make sure it didn't get bent as the valve body got tightened into place. If so you won't get it aligned properly and there will still be issues shifting
Re: 727 Wont shift into forward gears [Re: moparman89] #1603194
04/05/14 01:27 AM
04/05/14 01:27 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
went installing or removing the parking rod...move the driveshaft back n forth as needed..the rod will come out or go in easier.
Tony
70 AARCuda Vitamin C
Re: 727 Wont shift into forward gears [Re: moparman89] #1603195
04/05/14 02:54 AM
04/05/14 02:54 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Are you sure you have a 727 park rod? 904 park rod is different, but valve body works on both.
Re: 727 Wont shift into forward gears [Re: qwkmopardan] #1603196
04/05/14 05:38 AM
04/05/14 05:38 AM
Indy
Indy
Using the parking rod that came off the factory valve body...
Re: 727 Wont shift into forward gears [Re: moparman89] #1603197
04/05/14 05:17 PM
04/05/14 05:17 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
When stabbing the Park rod into the tail it's possible to get the rod positioned incorrectly below the parking pawl. (area in red box below) Best way to prevent this is to clock the snap ring all the way clockwise so the snap ring end will guide the rod into the tapered ramp.
Re: 727 Wont shift into forward gears [Re: John_Kunkel] #1603198
04/08/14 11:47 PM
04/08/14 11:47 PM
Indy
Indy
Got a new slip yoke so I can rotate the output shaft and hopefully get this thing together.
