727 Wont shift into forward gears
#1603188
04/04/14 07:57 PM
04/04/14 07:57 PM
Posts: 171 Indy
moparman89
Indy
Installed a Cheetah rev man valve body in my 727. I attempted to hook up the shifter linkage when I discovered that it will not shift into the forward gears. Even with the linkage unhooked it wont shift.
Dropped the pan and removed valve body, valve body shifts fine on the bench. What gives?
School of Automotive Machinists Racing
Re: 727 Wont shift into forward gears
[Re: moparman89]
#1603190
04/04/14 08:37 PM
04/04/14 08:37 PM
Posts: 25,821 Rio Linda, CA
John_Kunkel
Rio Linda, CA
When you fed the Park rod into the tail it might have misaligned with the hole, try it again and be sure the rod moves freely.
[Re: rickraw]
#1603192
04/04/14 09:41 PM
04/04/14 09:41 PM
Posts: 171 Indy
moparman89
Indy
Check the safety switch, not it. Took the parking rod off and reinstalled, works great.
Any tips for installing the parking rod, obviously I didnt get it right the first time.
[Re: John_Kunkel]
#1603198
04/08/14 11:47 PM
04/08/14 11:47 PM
Posts: 171 Indy
moparman89
Indy
Got a new slip yoke so I can rotate the output shaft and hopefully get this thing together.
