2001 Durango headlights won't turn on #1599702
03/28/14 02:32 PM
03/28/14 02:32 PM
Carson City, NV
babarracuda Offline OP
Carson City, NV
I was going to the store at 6:30AM and I turned on the headlights and nothing. I pulled out the owners manual and found the 2 locations for fuses. I could not find anything that resembles headlight in both fuse locations HELP!!!
Re: 2001 Durango headlights won't turn on [Re: babarracuda] #1599703
03/28/14 02:35 PM
03/28/14 02:35 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Do you have any marker lights? My guess would be the headlight switch is bad.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 2001 Durango headlights won't turn on [Re: Silver70] #1599704
03/28/14 07:08 PM
03/28/14 07:08 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree sounds like the switch.Did a few at work for the same thing.Rocky
Chrysler Firepower
Re: 2001 Durango headlights won't turn on [Re: therocks] #1599705
03/28/14 11:10 PM
03/28/14 11:10 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I just replaced a bad headlight switch on a 98. Marker lights came on, but no headlights.
However, the 00 year uses a different switch.
**Photobucket sucks**
Re: 2001 Durango headlights won't turn on [Re: 70Cuda383] #1599706
03/29/14 10:10 AM
03/29/14 10:10 AM
Carson City, NV
Carson City, NV
To add to the confusion, the high beams work, but no low beams.
Re: 2001 Durango headlights won't turn on [Re: babarracuda] #1599707
03/29/14 12:29 PM
03/29/14 12:29 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Check the switch on the column then. If high beams work, then power is getting from the headlight switch to the high/low switch on the column
Re: 2001 Durango headlights won't turn on [Re: 70Cuda383] #1599708
03/29/14 02:36 PM
03/29/14 02:36 PM
South Lyon MI
sleddinfool Offline
sleddinfool  Offline
South Lyon MI
I know it may sound stupid, but-- Did you verify the bulbs were good? On more then one occasion I have found two bad bulbs. They are so bright one does not notice until they both go out. Kevin
71 gtx.....
Re: 2001 Durango headlights won't turn on [Re: sleddinfool] #1599709
03/29/14 04:43 PM
03/29/14 04:43 PM
Carson City, NV
Carson City, NV
I suppose it couls be the low bulbs, but it is doubful as they were both brighta week ago when I check the lenses for dullness. I have no idea how to check the high/low switch. My other issue my back 3 level neck fusion and (2) 5 level low back surgeries which makes dash work a pain (really stiff and hurts). Oh to be young again!!!
Re: 2001 Durango headlights won't turn on [Re: babarracuda] #1599710
03/31/14 10:58 AM
03/31/14 10:58 AM
Carson City, NV
Carson City, NV
Got a shock yesterday. Both low beams were bad. I have heard of this but never seen it. New bulbs and now hadlights! WOW!
