Re: 2001 Durango headlights won't turn on
[Re: babarracuda]
#1599703
03/28/14 02:35 PM
03/28/14 02:35 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Do you have any marker lights? My guess would be the headlight switch is bad.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#1599704
03/28/14 07:08 PM
03/28/14 07:08 PM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
I agree sounds like the switch.Did a few at work for the same thing.Rocky
Chrysler Firepower
[Re: therocks]
#1599705
03/28/14 11:10 PM
03/28/14 11:10 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I just replaced a bad headlight switch on a 98. Marker lights came on, but no headlights.
However, the 00 year uses a different switch.
**Photobucket sucks**
[Re: babarracuda]
#1599707
03/29/14 12:29 PM
03/29/14 12:29 PM
70Cuda383
Marysville, O-H-I-O
Check the switch on the column then. If high beams work, then power is getting from the headlight switch to the high/low switch on the column
[Re: 70Cuda383]
#1599708
03/29/14 02:36 PM
03/29/14 02:36 PM
Posts: 1,800 South Lyon MI
sleddinfool
South Lyon MI
I know it may sound stupid, but-- Did you verify the bulbs were good? On more then one occasion I have found two bad bulbs. They are so bright one does not notice until they both go out. Kevin
71 gtx.....
