3rd gear issues in 727 #1598932
03/26/14 11:13 PM
03/26/14 11:13 PM
So.IL.
shaggy1 Offline OP
shaggy1  Offline OP
So.IL.
I have a 360/727 in my dart that doesn't want to go into 3rd. 1st to 2nd shifts fine, but it doesn't want to shift into third unless I am really standing in it, and only does when I let off of throttle a bit. After that it's fine until I start to get back around 30 mph or so, and then drops back to 2nd fairly hard. Just got this on the road, thought it was just shifter cable mis-adjusted but worked on it today and wasn't the issue. Don't know if I have all the right tv linkage, planning on ordering the bouchillion setup fri. Is there anything else I need to look for or do? Thanks in advance.
Re: 3rd gear issues in 727 [Re: shaggy1] #1598933
03/26/14 11:40 PM
03/26/14 11:40 PM
Wisconsin
beecrazy69 Offline
beecrazy69  Offline
Wisconsin
Sounds like the TV linkage is pushing the trans lever too far rearward.
Should be many of topics on this forum covering this.
Do you have 2 barrel linkage hooked to a 4 barrel?
Can you push the carb to WOT with the linkage hooked up, try unhooked first....
Re: 3rd gear issues in 727 [Re: shaggy1] #1598934
03/26/14 11:51 PM
03/26/14 11:51 PM
So.IL.
shaggy1 Offline OP
shaggy1  Offline OP
So.IL.
Have a stock intake with holley street avenger. Car had 318/904 when I bought it and just finished the 360/727 swap. I used the linkage that was on the 904, was wondering if that would make any diff. That's why I was gonna order the bouchillion setup, along with trying to clean up the mess that the previous owner had for throttle cable, etc.
Re: 3rd gear issues in 727 [Re: shaggy1] #1598935
03/26/14 11:59 PM
03/26/14 11:59 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The 904/ 2bbl setup is not the same as would be used a 727 with a 4bbl. this is the problem .
Re: 3rd gear issues in 727 [Re: shaggy1] #1598936
03/27/14 12:04 AM
03/27/14 12:04 AM
So.IL.
shaggy1 Offline OP
shaggy1  Offline OP
So.IL.
It was the same setup 4bbl with the 904, will that make a difference? Is the Bouchillon setup the way to go?
Re: 3rd gear issues in 727 [Re: shaggy1] #1598937
03/27/14 12:36 AM
03/27/14 12:36 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Yes it will and yes you do.
Re: 3rd gear issues in 727 [Re: shaggy1] #1598938
03/27/14 12:44 AM
03/27/14 12:44 AM
So.IL.
shaggy1 Offline OP
shaggy1  Offline OP
So.IL.
That's what I figured, but wasn't sure. It's been 15 yrs or so since I had an old mopar and seem to have forgotten a few things. To many ex-wives and adult beverages.
Re: 3rd gear issues in 727 [Re: shaggy1] #1598939
03/27/14 07:04 PM
03/27/14 07:04 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
solid rod all the way to trans or pivot at the back of manifold? All you need is to make the rod longer at the top, this could help the old lady issues too.
Re: 3rd gear issues in 727 [Re: shaggy1] #1598940
03/27/14 07:44 PM
03/27/14 07:44 PM
So.IL.
shaggy1 Offline OP
shaggy1  Offline OP
So.IL.
Bahahaha, funny. That's the only part that they enjoy, cant stand the rest. But seriously, thanks for everybodys help, already ordered the bpe kit this morning. Never did like fooling with the linkage even back then.
Re: 3rd gear issues in 727 [Re: shaggy1] #1598941
03/27/14 08:08 PM
03/27/14 08:08 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Have a stock intake with holley street avenger. mess that the previous owner had for throttle cable, etc.
Does the carb have the Mopar throttle lever extension? (Holley 20-7) Without it you'll never get the TP linkage to work correctly.
Re: 3rd gear issues in 727 [Re: shaggy1] #1598942
03/27/14 08:22 PM
03/27/14 08:22 PM
So.IL.
shaggy1 Offline OP
shaggy1  Offline OP
So.IL.
Yeah, I actually put it on myself shortly after buying the car. It had issues already, no wot and was pieced together with homemade extensions and basically crap. Had it working ok, but with a brand new 360 on a stand, well you know, I just couldn't stand it. So 8 3/4 3:91 suregrip, to replace the 7 1/4, meant the driveshaft was to long, so instead of cutting shaft twice, in went 360/727.
Re: 3rd gear issues in 727 [Re: shaggy1] #1598943
03/27/14 10:39 PM
03/27/14 10:39 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Where you located, Shaggy? I have a couple of boxes of kick down linkages. Some one piece and some multi. Should be plenty enough to fab up what you need.
Let me know if you are close enough and want some.
Master, again and still
Re: 3rd gear issues in 727 [Re: shaggy1] #1598944
03/28/14 12:20 AM
03/28/14 12:20 AM
So.IL.
shaggy1 Offline OP
shaggy1  Offline OP
So.IL.
Actually located not far from you DaveRS23. I'm in Hburg. I would take you up on that but have already ordered the BPE kit first thing this morning. Appreciate the thought though.
Re: 3rd gear issues in 727 [Re: John_Kunkel] #1598945
03/28/14 02:43 AM
03/28/14 02:43 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Had one give me trouble because of that. Get the TP right so its shifts right and has the downshift at the right speed but then you cant get full throttle. Adjust so you can get full throttle and then shift pattern is off and wont downshift. It can be very hard to impossible to get it right without the correct linkage for the right ratio. Ron
