Re: 3rd gear issues in 727
[Re: shaggy1]
#1598935
03/26/14 11:59 PM
03/26/14 11:59 PM
Posts: 75,282 A gulag near you.
JohnRR
A gulag near you.
Have a stock intake with holley street avenger. Car had 318/904 when I bought it and just finished the 360/727 swap. I used the linkage that was on the 904, was wondering if that would make any diff. That's why I was gonna order the bouchillion setup, along with trying to clean up the mess that the previous owner had for throttle cable, etc.
The 904/ 2bbl setup is not the same as would be used a 727 with a 4bbl. this is the problem .
[Re: shaggy1]
#1598943
03/27/14 10:39 PM
03/27/14 10:39 PM
Posts: 12,814 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
Where you located, Shaggy? I have a couple of boxes of kick down linkages. Some one piece and some multi. Should be plenty enough to fab up what you need.
Let me know if you are close enough and want some.
Master, again and still
