"mopar REAL" procomp distributor? #159813
12/01/08 08:32 PM
12/01/08 08:32 PM
Anonymous OP
Anonymous OP
has anyone seen or is using this setup?170 bucks,free shipping.you get distributor,coil & wires.there is an example on ebay-#140284917352.I have a high RPM miss with my summit electronic system.I had no problems with my original point distributor system.[1968 440 motor]
Re: "mopar REAL" procomp distributor? #159814
12/01/08 08:39 PM
12/01/08 08:39 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
I am thinking of going this route..
For more mild street applications, we also have our Ready to Run Street distributor. These feature a simple 2 wire hookup, and no external ignition box is required. A completely maintenance free magnetic pickup accurately triggers the ignition system. The increased output of the internal ignition system included in these far outperforms a stock ignition and will help to smooth out the engines idle, make starting easier, and provide a stable spark, even at higher engine RPM's. These also feature a performance advance curve setup at the factory, and a vacuum advance is included to help with fuel economy. Just like the PRO BILLET versions, these use "Spark Plug" style locking terminals on the cap to ensure a positive connection. Color of the cap may vary depending on stock. An excellent choice for street use.
This distributor can also be used with a "female" (factory type) cap, see our part number 117-1011 below.
Part No: 117-1002 - Street Distributor - "RB" - Ready to Run - NEW - Price: $74.95
Re: "mopar REAL" procomp distributor? #159815
12/01/08 08:57 PM
12/01/08 08:57 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
I bought 4 sets from pro comp..2 small and 2 big block sets and they are worth every penny
Re: "mopar REAL" procomp distributor? [Re: terzmo] #159816
12/01/08 09:21 PM
12/01/08 09:21 PM
fresno ca
wildfish72 Offline
mopar addict
wildfish72  Offline
mopar addict
fresno ca
same here , ive got the hole setup , works great , its pretty much a msd with a better dollar price
Re: "mopar REAL" procomp distributor? #159817
12/01/08 09:29 PM
12/01/08 09:29 PM
templeton,ma
coro500net Offline
coro500net  Offline
templeton,ma
I have the ready to run in my RB,so far works
great.
Re: "mopar REAL" procomp distributor? [Re: coro500net] #159818
12/01/08 10:27 PM
12/01/08 10:27 PM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
I've got the digital E curve on my small block. Worth every penny and then some. Best ignition $$$ I have ever spent.
