"mopar REAL" procomp distributor?
#159813
12/01/08 08:32 PM
12/01/08 08:32 PM
has anyone seen or is using this setup?170 bucks,free shipping.you get distributor,coil & wires.there is an example on ebay-#140284917352.I have a high RPM miss with my summit electronic system.I had no problems with my original point distributor system.[1968 440 motor]
Re: "mopar REAL" procomp distributor?
#159814
12/01/08 08:39 PM
12/01/08 08:39 PM
340dart4spd
Parts Problem
Parts Problem
I am thinking of going this route..
For more mild street applications, we also have our Ready to Run Street distributor. These feature a simple 2 wire hookup, and no external ignition box is required. A completely maintenance free magnetic pickup accurately triggers the ignition system. The increased output of the internal ignition system included in these far outperforms a stock ignition and will help to smooth out the engines idle, make starting easier, and provide a stable spark, even at higher engine RPM's. These also feature a performance advance curve setup at the factory, and a vacuum advance is included to help with fuel economy. Just like the PRO BILLET versions, these use "Spark Plug" style locking terminals on the cap to ensure a positive connection. Color of the cap may vary depending on stock. An excellent choice for street use.
This distributor can also be used with a "female" (factory type) cap, see our part number 117-1011 below.
Part No: 117-1002 - Street Distributor - "RB" - Ready to Run - NEW - Price: $74.95
