71 Roadrunner 383 4-speed Holley Solenoid Question #1592084
03/12/14 07:06 PM
03/12/14 07:06 PM
Clancy, Montana
celcius232 Offline OP
Clancy, Montana
The original Chrysler shop manual is vague about the wiring to the carb solenoid on a 71 383 4-speed car (Holley R-6191A; non-air grabber). I think the original engine harness is still in the car and unaltered. There is a white round female end plug on the harness --did that possibly goes to the carb solenoid? The original solenoid has two 18 gauge wires coming off and according to the manual, one is to the distributor ground switch and the other to solenoid lead. Can anyone clarify what is correct and how to get it back to original? Thanks in advance.
Re: 71 Roadrunner 383 4-speed Holley Solenoid Question [Re: celcius232] #1592085
03/12/14 07:07 PM
03/12/14 07:07 PM
Clancy, Montana
Clancy, Montana
Another pic of the plug end.
Re: 71 Roadrunner 383 4-speed Holley Solenoid Question [Re: celcius232] #1592086
03/12/14 07:12 PM
03/12/14 07:12 PM
Clancy, Montana
Clancy, Montana
Shop manual pic, the car was built in the St. Louis plant in March 1971.
8071651-4160page652-2.pdf (107 downloads)
Re: 71 Roadrunner 383 4-speed Holley Solenoid Question [Re: celcius232] #1592087
03/12/14 08:19 PM
03/12/14 08:19 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Somebody has added that plug . I looked at my old harness, that thing ain't on it. Even the digram doesn't show anything that looks like that.
Re: 71 Roadrunner 383 4-speed Holley Solenoid Question [Re: 71birdJ68] #1592088
03/12/14 09:43 PM
03/12/14 09:43 PM
Clancy, Montana
Clancy, Montana
What I suspected--too strange to be original. Someone may have tried an aftermarket solenoid that used that plug.
Does anyone know if the replacement M&H engine wiring harnesses have the correct plug-ins for the solenoid?
Re: 71 Roadrunner 383 4-speed Holley Solenoid Question [Re: celcius232] #1592089
03/12/14 09:57 PM
03/12/14 09:57 PM
Clancy, Montana
Clancy, Montana
I checked M&H and they list a carb solenoid harness for the 71 383 4-speed (B&E Body), Part No. L38496
Re: 71 Roadrunner 383 4-speed Holley Solenoid Question [Re: celcius232] #1592090
03/12/14 10:28 PM
03/12/14 10:28 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Actually that plug looks like a DN connector that used to come on some car stereos.I don't know who Frank Baldson gets his harness from, but you could ck with him also. Is that the original carb? I thought only Air Grabber cars got a Holly.
Re: 71 Roadrunner 383 4-speed Holley Solenoid Question [Re: 71birdJ68] #1592091
03/12/14 11:22 PM
03/12/14 11:22 PM
Clancy, Montana
Clancy, Montana
A Holley 4160 is factory correct for the '71 383 motors. Mine has a 4668 carb on it now. According to the shop manual the 4668 carb is correct for a '71 383 Automatic. A Holley 6191 was specified for the 383 4-speed motors (B&E body). From what I have read, a lot of these Holleys were replaced by dealers with Carter AFBs due to leakage problems. Mine is leaking around the secondary bowl and transfer tube. Hopefully some new gaskets will solve the problem.
Mine is also missing the choke diaphragm link so if anyone has one, let me know. I am going to try to bend from 3/32 welding rod based on some pics I have--maybe I can get close enough to have an operable choke--you really need one in Montana.
Re: 71 Roadrunner 383 4-speed Holley Solenoid Question [Re: celcius232] #1592092
03/13/14 12:08 AM
03/13/14 12:08 AM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
That is not the proper connector and m&h is where I went also but of coarse you have to go through year one. If I remember correctly it also ties into the distributor vac advance. I could get you a photo if the car was not in storage. If you would like a photo I can get it but it would be a few days.
Re: 71 Roadrunner 383 4-speed Holley Solenoid Question [Re: celcius232] #1592093
03/13/14 12:26 AM
03/13/14 12:26 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
One thing to notice. If that carb has a plastic ramp that the acc pump arm travels on it can wear a grove on it and the pump will pump late or not enough, and you will have a nice bog. I remember that from my original carb.
