71 Cuda with fast ratio pitman arm original? #1589121
03/07/14 09:58 AM
03/07/14 09:58 AM
Md.
J Brough Offline OP
J Brough  Offline OP
Md.
I am working on a 71 Cuda. Original 340 shaker hood car. Power steering pump is leaking and needs rebuilt. Noticed that it has a fast ratio pitman arm on it. Owner bought car new in 71 and tells me that steering is all original. Was fast ratio a 71 option?
Thanks,
John Brough
Re: 71 Cuda with fast ratio pitman arm original? [Re: J Brough] #1589122
03/07/14 10:26 AM
03/07/14 10:26 AM
Grand Rapids MI
N
N9671X2 Offline
N9671X2  Offline
N
Grand Rapids MI
Yes it was, on build sheet but not on tag. Have had several of them. Pretty sure it was a 340 thing only, you should also notice the date casting is after the T/A car period
Re: 71 Cuda with fast ratio pitman arm original? [Re: N9671X2] #1589123
03/07/14 02:27 PM
03/07/14 02:27 PM
MD
floyd Offline
floyd  Offline
MD
Re: 71 Cuda with fast ratio pitman arm original? [Re: floyd] #1589124
03/07/14 07:23 PM
03/07/14 07:23 PM
Md.
J Brough Offline OP
J Brough  Offline OP
Md.
I assume that the Cuda would be the same as indicated in the Dodge Challenger TSB. Looks like the owner needs to be careful with getting this unit rebuilt since it looks like there are a number of special parts. Any recommendations for a good rebuilder?
I am in Southern Md. Indian Head area.
Regards,
John
Re: 71 Cuda with fast ratio pitman arm original? [Re: J Brough] #1589125
03/07/14 08:02 PM
03/07/14 08:02 PM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
I recommend Firm Feel Inc and ask for Dick, he is a good guy and does quality rebuilt work.
Re: 71 Cuda with fast ratio pitman arm original? [Re: J Brough] #1589126
03/07/14 08:08 PM
03/07/14 08:08 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: 71 Cuda with fast ratio pitman arm original? [Re: Alaskan_TA] #1589127
03/09/14 03:09 PM
03/09/14 03:09 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
yes there is a big difference in steering between my 71 and 70 for sure..
Re: 71 Cuda with fast ratio pitman arm original? [Re: Alaskan_TA] #1589128
03/10/14 08:50 AM
03/10/14 08:50 AM
Md.
J Brough Offline OP
J Brough  Offline OP
Md.
Thanks to all for the help and advice. The box does have the TA cast into it, so I suspect that it is original. In my original post I misspoke, the steering gear is leaking, not the pump. Anyway, I'll let the owner know what I found out and see how he wants to proceed. Thanks again for the help.
John Brough
Re: 71 Cuda with fast ratio pitman arm original? [Re: J Brough] #1589129
03/11/14 02:00 PM
03/11/14 02:00 PM
Strathroy, Ontario
BS27R1B Offline
BS27R1B  Offline
Strathroy, Ontario
I have heard that the quick ratio steering came on all 3.91 rear differential cars. Any truth to this or did all 71 340 cars built after February 1 1971 come with the TA box.
Were they also not equipped with a power steering cooler?
'.. it was long ago and it was far away, and it was so much better than it is today..'
Jim Steinman
Re: 71 Cuda with fast ratio pitman arm original? [Re: BS27R1B] #1589130
03/11/14 02:50 PM
03/11/14 02:50 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The TSB implies ALL 71 340 after that date.
I've seen a 70K mine 71 340, A/C, auto, loaded, conv Challenger with quick steering.
