Page 1 of 3 1 2 3
Correct Oil filters... #1588259
03/05/14 01:22 AM
03/05/14 01:22 AM
Phoenix, AZ
MCTPhoenix Offline OP
Phoenix, AZ
What's the difference, if any, between an assembly line oil filter and an NOS dealership parts counter replacement of the era? Should the assembly line unit be spray bombed orange like the manifolds and battery cable to be correct? What's the best repro to use? Thanks!
Re: Correct Oil filters... [Re: MCTPhoenix] #1588260
03/05/14 02:27 AM
03/05/14 02:27 AM
I've heard that the filters were masked off and only got a little (if any) engine color on the base of it.
What year car are you working on? 1972 and up got a red,white, and blue from the factory. Prior to that was the green textured oil filters.
Re: Correct Oil filters... [Re: ] #1588261
03/05/14 06:01 PM
03/05/14 06:01 PM
Phoenix, AZ
Phoenix, AZ
'69 Charger with a 440. Not sure I've ever seen a green textured oil filter? Anyone have some photos?
Re: Correct Oil filters... [Re: MCTPhoenix] #1588262
03/05/14 06:03 PM
03/05/14 06:03 PM
michigan
70 buzz Offline
70 buzz  Offline
michigan
here you go
Re: Correct Oil filters... [Re: 70 buzz] #1588263
03/05/14 07:06 PM
03/05/14 07:06 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Try to buy one. You will pass out when you see the price.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Correct Oil filters... [Re: MOPARMIKE69] #1588264
03/05/14 07:12 PM
03/05/14 07:12 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Do what I did, go to a local sign shop, and show a picture and have them make a decal like the one above, then find a close shade of green paint, and paint you filter. Some of the factory filters had a raised M on the top of the filter.Its hard to tell way down in the engine bay if it's real or not.
Re: Correct Oil filters... [Re: 71birdJ68] #1588265
03/05/14 07:43 PM
03/05/14 07:43 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
A bit of bondo or similar and some artistry and you can have the "M" too
Re: Correct Oil filters... [Re: ScottSmith_Harms] #1588266
03/05/14 09:35 PM
03/05/14 09:35 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
These 2 photos look similar but not exactly.
http://www.iccahome.org/ > 'Engine Compartment' and scroll almost halfway down.
Are these the same filter as above? Don't see any green.
Re: Correct Oil filters... [Re: 70 buzz] #1588267
03/05/14 09:42 PM
03/05/14 09:42 PM
Phoenix, AZ
Phoenix, AZ
What's it say below the R on the right side? Anything on the back of the filter? part# ? Thanks!
Re: Correct Oil filters... [Re: MCTPhoenix] #1588268
03/05/14 10:29 PM
03/05/14 10:29 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Part number is 1851658.
They are the same green filters that you scroll down to, just a lighter shade of green.
Like a lot of parts these I believe were painted in batches.
In the past I have seen/owned two cases of 12 each and the colors varied in shade in both cases.
I have also owned some smooth ones, exact as the textured ones, print and all except the top M is not as pronounced as seen here, smoothie on the left.
Even the boxes were different shade and the one on left lacked the 10-26-6 reference
Re: Correct Oil filters... [Re: ScottSmith_Harms] #1588269
03/05/14 10:31 PM
03/05/14 10:31 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I cut the "M" out of a magnetic sticker that way I can peal it off then reinstall it on the next tall napa gold filter before I paint it.. I made up a stencil for the script.. I even add the texture every once in a while but I change each filter every year so sometimes I get lazy...
Re: Correct Oil filters... [Re: screamindriver] #1588270
03/05/14 10:37 PM
03/05/14 10:37 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Picture of Hemi with the filter from a 1968 Brochure.
Somewhere I have a 1966 Plymouth Satellite ad and in the picture the Hemi engine is dangling above engine compartment and has the green filter.
Note the 4 blade fan.
Re: Correct Oil filters... [Re: mccannix] #1588271
03/05/14 10:47 PM
03/05/14 10:47 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Box that contained 12 green Mopar filters, this batch being dated 2-68.
Re: Correct Oil filters... [Re: mccannix] #1588272
03/05/14 10:48 PM
03/05/14 10:48 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
good shot of the texture...back side
Re: Correct Oil filters... [Re: mccannix] #1588273
03/05/14 11:30 PM
03/05/14 11:30 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
You could sprinkle a little sand while the paint is wet, and then repaint it to get the texture.
Re: Correct Oil filters... [Re: mccannix] #1588274
03/06/14 12:39 AM
03/06/14 12:39 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Is there any danger running a filter that old?I think I'd be afraid the paper filter element might come apart.
Re: Correct Oil filters... [Re: 71birdJ68] #1588275
03/06/14 12:53 AM
03/06/14 12:53 AM
michigan
70 buzz Offline
70 buzz  Offline
michigan
agreed
Re: Correct Oil filters... [Re: ScottSmith_Harms] #1588276
03/06/14 04:10 AM
03/06/14 04:10 AM
Helsinki, Finland
Anselmi Offline
Anselmi  Offline
Helsinki, Finland
When was the "M" introduced to these filters? Was the top just smooth before that? Or with the "Arrow" logo maybe? Any information/pics of the real early (or 1962/1963 in my case) 1851658 oil filters?
'66 Plymouth
'64 Dodge
'63 Plymouth x 3
Re: Correct Oil filters... [Re: pushbutton] #1588277
03/06/14 05:07 AM
03/06/14 05:07 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
The "real" ones cost so much that likely nobody who has bought one (or more) uses them as actual oil filters. These are bona fide investment grade collector's items.
On the other hand, maybe one of these filters in mint but used condition is still worth plenty - about as much as a Hemi engine, or close to it, you think?
Re: Correct Oil filters... [Re: kentj340] #1588278
03/06/14 05:44 AM
03/06/14 05:44 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Page 1 of 3 1 2 3
