CLUTCH #1582692
02/23/14 01:55 AM
02/23/14 01:55 AM
washington
AB&E Offline OP
AB&E  Offline OP
washington
Which clutch is most prefered centerforce or mccloud ??
Re: CLUTCH [Re: AB&E] #1582693
02/23/14 09:51 AM
02/23/14 09:51 AM
MICHIGAN
BB65Barracuda Offline
MICHIGAN
I ran centerforce and it worked great for a pavement ponder!!!
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: CLUTCH [Re: BB65Barracuda] #1582694
02/23/14 10:18 AM
02/23/14 10:18 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
X2 on the CF.Mine has been in 10 years at least.Still hooks like new.Rocky
Chrysler Firepower
Re: CLUTCH [Re: AB&E] #1582695
02/23/14 12:32 PM
02/23/14 12:32 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
I think they're both OK. I did break a spring in the disc of my 10.95 McCleod, but I suppose that could happen to anyone's product. Lots of people use Centerforce, I've just never cared for the use of centrifugal weights on a pressure plate. Presently I run a Sachs 10.75 and it hooks tight and has a lighter pedal than the McCleod. Nice progressive take up. Sachs also makes the OEM clutches for some high end cars. Not as well known in the Hot Rod industry, but an excellent product.
Re: CLUTCH [Re: 5spdcuda] #1582696
02/23/14 02:50 PM
02/23/14 02:50 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
I'm sold on Centerforce. If light pedal pressure is at all a selling feature for you. Look no further.
Holding back power does not mean your pedal needs to be hard to push.
I'm tired of worn linkages, bending Z bars and flexing the firewall just because the last clutch was slipping. Not to mention the leg and knee of us older drivers.
Re: CLUTCH [Re: AB&E] #1582697
02/23/14 04:22 PM
02/23/14 04:22 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I've always liked McLeod but I'm going with a mix of both this year, Centerforce plate and McLeod disc with Hays flywheel
Gus
64 Plymouth Savoy
Dana 60
Re: CLUTCH [Re: AB&E] #1582698
02/23/14 04:26 PM
02/23/14 04:26 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
What's the application ????????????
Re: CLUTCH [Re: Stanton] #1582699
03/02/14 12:13 AM
03/02/14 12:13 AM
washington
AB&E Offline OP
AB&E  Offline OP
washington
Sorry got busy elswhere. My app is 1969 super bee 440-6,4spd,373 dana
I have had centerforce d/f for years in 4x4 app. & yes pedal pressure is a concerne so I think will order a ceneterforce dual friction. But the throw out is nuts!! what about running mc cloud tb & centerforce clutch.???
Re: CLUTCH [Re: AB&E] #1582700
03/02/14 12:26 AM
03/02/14 12:26 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run an OE Timken tb I found.Works great.Rocky
Chrysler Firepower
Re: CLUTCH [Re: therocks] #1582701
03/02/14 03:32 PM
03/02/14 03:32 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I run an E-body with a Center Force. It's the best clutch I've ever owned. No chatter, slip, pedal pressure is great. It's my wife's car. Small block 12.50@110
Doug
Re: CLUTCH [Re: AB&E] #1582702
03/02/14 11:42 PM
03/02/14 11:42 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
But how do you all feel about mixing tb brands vs clutch brands ?? Im thinking no big deal . see centerforce is like 150 & everyone else is 50-80 bucks > what do you think a poor guy should do? is the centerforce tb that much better?
Re: CLUTCH [Re: AB&E] #1582703
03/03/14 10:11 AM
03/03/14 10:11 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
When I got my CF it was a kit.Clutch PP and TOB.The car sat for a while after install and the TB made noise.Then my buddy at the parts store found a new Timken TB for me that sat on the shelf for like 8 years.No problems at all.Rocky
Chrysler Firepower
Re: CLUTCH [Re: therocks] #1582704
03/03/14 11:15 AM
03/03/14 11:15 AM
Ohio
dobie Offline
dobie  Offline
Ohio
Im using a McLeod 11" set up I bought from Brewer's several years ago. No issues so far. A neighbor of mine works for Luk Clutch as a R&D engineer however, so my next clutch will be a Luk.
1968 Plymouth Road Runner 383 4 speed
Re: CLUTCH [Re: dobie] #1582705
03/03/14 06:59 PM
03/03/14 06:59 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Where does one find a LUK clutch?...I see people mention them, but can't find anyone that carries them....
Re: CLUTCH [Re: Quicksilver440] #1582706
03/03/14 10:28 PM
03/03/14 10:28 PM
Rittman Ohio
Rittman Ohio
Next to the pumpkin farm on state rt. 585 in Wooster Ohio
The factory and R&D center is about 15 minutes away from me.
I will do some checking locally for your
Gus
64 Plymouth Savoy
Dana 60
Re: CLUTCH [Re: fourgearsavoy] #1582707
03/04/14 01:02 AM
03/04/14 01:02 AM
Central Valley, CA.
Central Valley, CA.
Lol..I'm in Bakersfield California. No mail order places? I googled with little success...
Re: CLUTCH [Re: Quicksilver440] #1582708
03/04/14 01:23 AM
03/04/14 01:23 AM
Rittman Ohio
Rittman Ohio
I know a few guys in the auto parts business what flywheel and spline do you have?
Most stock type clutch kit companies don't offer an 18 spline unit.
Gus
64 Plymouth Savoy
Dana 60
Re: CLUTCH [Re: fourgearsavoy] #1582709
03/04/14 02:02 AM
03/04/14 02:02 AM
Central Valley, CA.
Central Valley, CA.
Its a 23 spline....planning to buy the 11" jegs flywheel for $100 and a used scattershield (seems as cheap as a used bell and bottom cover).
Its going into a true daily driver with a real mild rebuilt 440. So pedal pressure needs to be where my 16 year old son and wife can drive it and not hate it. It will have a hydraulic master/slave if it matters.
Re: CLUTCH [Re: Quicksilver440] #1582710
03/04/14 11:01 AM
03/04/14 11:01 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
If you run a hydro clutch you can run any PP setup.The hydro takes all the pressure.Its not like a mechanical linkage.The CF with mechanical link is an easy setup.Pretty much no pressure.I dont know how I could trust a 100 buck flywheel.Id have more faith in a stock wheel thats in good shape.The shield is a good idea.You know you can run a 10 1/2 clutch with a shield.Just need to move the starter in on the shield.Rocky
Chrysler Firepower
Re: CLUTCH [Re: Quicksilver440] #1582711
03/04/14 11:06 AM
03/04/14 11:06 AM
Ohio
dobie Offline
dobie  Offline
Ohio
Yeah, Luk is actually about 5 minutes from me. I don't know of any store per se that carries them. Typically you have to know someone who works there.
Like I said, a neighbor and good friend of mine is an R&D guy there. He's offered several times to "hook me up" when I need a new package.
