Re: CLUTCH
[Re: BB65Barracuda]
#1582694
02/23/14 10:18 AM
02/23/14 10:18 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
X2 on the CF.Mine has been in 10 years at least.Still hooks like new.Rocky
Chrysler Firepower
Re: CLUTCH
[Re: 5spdcuda]
#1582696
02/23/14 02:50 PM
02/23/14 02:50 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
I'm sold on Centerforce. If light pedal pressure is at all a selling feature for you. Look no further.
Holding back power does not mean your pedal needs to be hard to push.
I'm tired of worn linkages, bending Z bars and flexing the firewall just because the last clutch was slipping. Not to mention the leg and knee of us older drivers.
Re: CLUTCH
[Re: AB&E]
#1582700
03/02/14 12:26 AM
03/02/14 12:26 AM
therocks
Niles , Ohio
I run an OE Timken tb I found.Works great.Rocky
Chrysler Firepower
Re: CLUTCH
[Re: therocks]
#1582701
03/02/14 03:32 PM
03/02/14 03:32 PM
Posts: 9,881 MI, usa
dvw
MI, usa
I run an E-body with a Center Force. It's the best clutch I've ever owned. No chatter, slip, pedal pressure is great. It's my wife's car. Small block 12.50@110Doug
Re: CLUTCH
[Re: AB&E]
#1582703
03/03/14 10:11 AM
03/03/14 10:11 AM
therocks
Niles , Ohio
When I got my CF it was a kit.Clutch PP and TOB.The car sat for a while after install and the TB made noise.Then my buddy at the parts store found a new Timken TB for me that sat on the shelf for like 8 years.No problems at all.Rocky
Chrysler Firepower
Re: CLUTCH
[Re: Quicksilver440]
#1582708
03/04/14 01:23 AM
03/04/14 01:23 AM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I know a few guys in the auto parts business what flywheel and spline do you have? Most stock type clutch kit companies don't offer an 18 spline unit. Gus ![](/ubbthreads/images/graemlins/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: CLUTCH
[Re: fourgearsavoy]
#1582709
03/04/14 02:02 AM
03/04/14 02:02 AM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
Its a 23 spline....planning to buy the 11" jegs flywheel for $100 and a used scattershield (seems as cheap as a used bell and bottom cover).
Its going into a true daily driver with a real mild rebuilt 440. So pedal pressure needs to be where my 16 year old son and wife can drive it and not hate it. It will have a hydraulic master/slave if it matters.
Re: CLUTCH
#1582710
03/04/14 11:01 AM
03/04/14 11:01 AM
therocks
Niles , Ohio
If you run a hydro clutch you can run any PP setup.The hydro takes all the pressure.Its not like a mechanical linkage.The CF with mechanical link is an easy setup.Pretty much no pressure.I dont know how I could trust a 100 buck flywheel.Id have more faith in a stock wheel thats in good shape.The shield is a good idea.You know you can run a 10 1/2 clutch with a shield.Just need to move the starter in on the shield.Rocky
Chrysler Firepower
Re: CLUTCH
#1582711
03/04/14 11:06 AM
03/04/14 11:06 AM
Posts: 1,032 Ohio
dobie
Ohio
Yeah, Luk is actually about 5 minutes from me. I don't know of any store per se that carries them. Typically you have to know someone who works there.
Like I said, a neighbor and good friend of mine is an R&D guy there. He's offered several times to "hook me up" when I need a new package.
1968 Plymouth Road Runner
383 4 speed
