ATTN: Weber Belt Drive Users #1579845
02/16/14 05:35 PM
02/16/14 05:35 PM
Tulsa, Oklahoma
340Cuda Offline OP
340Cuda  Offline OP
Tulsa, Oklahoma
I fired up a new engine with a Weber Belt Drive for the first time today. It has a pretty bad oil leak in the front. I at this time I cannot see if it is coming from the crank or the cam.
Have any of you guys seen this movie and can you give me advice as to what to look for as I take it apart?
I thought I followed the instructions closely.
It is a R-3 Block with a 60mm cam.
Thanks,
Bill Lamb
Re: ATTN: Weber Belt Drive Users [Re: 340Cuda] #1579846
02/16/14 05:40 PM
02/16/14 05:40 PM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
I have a weber belt drive but the standard 48* babbit bearing set up but no leaks for me.
Hopefully you didn't tear up the crank seal call Dave and ask him for info. I have his cell no if you need it.
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: ATTN: Weber Belt Drive Users [Re: 440W8 Duster] #1579847
02/17/14 12:25 AM
02/17/14 12:25 AM
Tulsa, Oklahoma
340Cuda Offline OP
340Cuda  Offline OP
Tulsa, Oklahoma
Jesse,
I have got another crank seal if I need it, its a Jesel part number. I am hoping it will be obvious what the problem is when I get it apart. I don't remember anyone ever saying they had problems with leaks.
Thanks,
Bill
Re: ATTN: Weber Belt Drive Users [Re: 340Cuda] #1579848
02/17/14 01:53 AM
02/17/14 01:53 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Something had to be cut down on my cam adapter when I went to 60mm. But, for the life of me I can't remember what it was.
Leon
Re: ATTN: Weber Belt Drive Users [Re: Leon441] #1579849
02/17/14 11:35 AM
02/17/14 11:35 AM
Tulsa, Oklahoma
340Cuda Offline OP
340Cuda  Offline OP
Tulsa, Oklahoma
Leon,
Thanks!
Let me know if you remember, but this gives me something to ask Weber about.
Bill
Re: ATTN: Weber Belt Drive Users [Re: 340Cuda] #1579850
02/17/14 08:12 PM
02/17/14 08:12 PM
San Antonio,TX
San Antonio,TX
Did you put some silicone between the crank key and crank gear? Also some on the cam seal (cover)?
70 Duster W8 motor.
@3170 lbs.
Re: ATTN: Weber Belt Drive Users [Re: 440W8 Duster] #1579851
02/18/14 12:03 AM
02/18/14 12:03 AM
408Dust Offline
408Dust  Offline
Make sure you did not roll the cam seal have been running one for some time and never had a problem but have rolled the cam seal but it did not leak....
Re: ATTN: Weber Belt Drive Users [Re: Leon441] #1579852
02/18/14 06:08 PM
02/18/14 06:08 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Leon
usually you need to cut the front cam journal down to stock size for .250 back to allow the cam adapter to sit on the bigger core correctly.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: ATTN: Weber Belt Drive Users [Re: bigtimeauto] #1579853
02/18/14 08:46 PM
02/18/14 08:46 PM
Tulsa, Oklahoma
340Cuda Offline OP
340Cuda  Offline OP
Tulsa, Oklahoma
Thanks everyone!
Lots of things to check and look at.
Bill
