Re: ATTN: Weber Belt Drive Users
[Re: 340Cuda]
#1579846
02/16/14 05:40 PM
02/16/14 05:40 PM
Posts: 1,499 San Antonio,TX
440W8 Duster
San Antonio,TX
I have a weber belt drive but the standard 48* babbit bearing set up but no leaks for me. Hopefully you didn't tear up the crank seal call Dave and ask him for info. I have his cell no if you need it.
70 Duster W8 motor. 1.29 60ft 5.79 1/8 at 120 mph glide with 1.80 gear @3170 lbs.
[Re: 340Cuda]
#1579848
02/17/14 01:53 AM
02/17/14 01:53 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Something had to be cut down on my cam adapter when I went to 60mm. But, for the life of me I can't remember what it was.
Leon
[Re: 340Cuda]
#1579850
02/17/14 08:12 PM
02/17/14 08:12 PM
440W8 Duster
San Antonio,TX
Did you put some silicone between the crank key and crank gear? Also some on the cam seal (cover)?
