BB Aluminum intake question #1573632
02/03/14 05:41 PM
02/03/14 05:41 PM
Lakeland FL
floridian Offline OP
Lakeland FL
So where do I bolt my kickdown linkage on an aftermarket aluminum intake with NO mounting area for it?? Are there any brackets made for this?? I can't seem to find anything.. Thanks for any help here..
Re: BB Aluminum intake question [Re: floridian] #1573633
02/03/14 05:44 PM
02/03/14 05:44 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
AR Engineering has the bracket you need. I believe this may be it.
http://chucker54.stores.yahoo.net/thbrwikido4v.html
Re: BB Aluminum intake question [Re: floridian] #1573634
02/03/14 05:48 PM
02/03/14 05:48 PM
Most of the early Mopar inatke manifolds for BB V8 did not come with any provisions to mount a bracket to hold the kickdown linkage the pivot, if it was a three piece kickdown set up, was on the throttle cable bracket IHTHs, BTW a Lokar cable set up may be your best and only choice if you don't want to make a brqcket for your kickdown linkage. What size and year motor are you working on?
Re: BB Aluminum intake question [Re: floridian] #1573635
02/03/14 06:22 PM
02/03/14 06:22 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
A picture of the linkage you are using and/or a description of the linkage would be helpful .
Re: BB Aluminum intake question [Re: JohnRR] #1573636
02/04/14 11:41 AM
02/04/14 11:41 AM
Lakeland FL
Lakeland FL
Good point John, Car in the pic using the stock kickdown linkage that came in the 67 coronet.. rods and belcranks..
I have seen a bracket for sale that mounts under the carb, but I believe that its only for the throttle cable..
I guess this intake is for manual transmissions only??
Re: BB Aluminum intake question [Re: Cab_Burge] #1573637
02/04/14 11:43 AM
02/04/14 11:43 AM
Lakeland FL
Lakeland FL
67 coronet, stock 440/727... Not really interested in using a Lokar after market K/D linkage...
Re: BB Aluminum intake question [Re: floridian] #1573638
02/04/14 12:30 PM
02/04/14 12:30 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
??? just bolt it where it goes normally, to the last intake bolt. I HATED the Lokar on my old 67, I tore it off after one day at the track and went back to the stock piece.
Coming soon!!!!
Re: BB Aluminum intake question [Re: floridian] #1573639
02/04/14 02:36 PM
02/04/14 02:36 PM
JohnRR Offline
JohnRR  Offline
If you are using the stock linkage now it doesn't bolt to the intake ???
Since you have a 440 already how is it currently connected ? What intake are you swapping to and what carb are you running ???
Re: BB Aluminum intake question [Re: Mr.Yuck] #1573640
02/04/14 02:40 PM
02/04/14 02:40 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
As Mr Yuck said. The two rearmost intake bolts on the drivers side hold the bracket.
Re: BB Aluminum intake question [Re: roadhazard] #1573641
02/04/14 02:46 PM
02/04/14 02:46 PM
JohnRR Offline
JohnRR  Offline
that's the 1 piece linkage , he has the 3 piece , but it's the same concept of how it bolts on , last intake bolt holds the bracket. This is what he should currently have .
Re: BB Aluminum intake question [Re: JohnRR] #1573642
02/07/14 02:42 PM
02/07/14 02:42 PM
Lakeland FL
Lakeland FL
Based on my memory that pic is the correct bracket but it bolts into the same hole as the throttle cable bracket does, as in the above pic with the incorrect 1pc linkage NOT to the intake to head bolts. Do any Aluminum intakes come with this or do I need to purchase the aftermarket bracket from the second poster??
Re: BB Aluminum intake question [Re: floridian] #1573643
02/07/14 03:36 PM
02/07/14 03:36 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Man I think you need to just post a pic up of what you have going on there
All intakes are the same, NO special provisions for any brackets or levers.
Re: BB Aluminum intake question [Re: floridian] #1573644
02/07/14 05:54 PM
02/07/14 05:54 PM
AndyF Online content
AndyF  Online Content
I solved this problem 10 years ago when I designed the taller kickdown bracket for B and RB engines. I've sold a few thousand of those brackets over the past decade. I designed my brackets to work with the Performer RPM intakes, but they'll fit others as well as long as the height isn't too different from the RPM.
Re: BB Aluminum intake question [Re: floridian] #1573645
02/08/14 01:43 PM
02/08/14 01:43 PM
JohnRR Offline
JohnRR  Offline
NO the throttle cable AND the kickdown linkage both bolt to the EXACT SAME BRACKET, see that silver clamp on top , that's where the throttle cable goes USE WHAT YOU CURRENTLY HAVE .... there is no big block intake ... except the 440 6pk and maybe the Max Wedge dual quad ... where any bracket bolts to the intake itself ... the picture with the 1 piece linkage also use a bracket that bolts to the engine by way of the intake bolts, it uses 2 instead of 1 and the throttle linkage bolts to it also.
Re: BB Aluminum intake question [Re: JohnRR] #1573646
02/08/14 05:46 PM
02/08/14 05:46 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I admire your tenacity.
Re: BB Aluminum intake question [Re: JohnRR] #1573647
02/10/14 11:38 AM
02/10/14 11:38 AM
Lakeland FL
Lakeland FL
If you haven't seen my other post the above comment by JohnRR is correct. My apologies for the wild goose chase here.. Too many Martini's at Manny's.......
Re: BB Aluminum intake question [Re: floridian] #1573648
02/10/14 05:40 PM
02/10/14 05:40 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Glad to know you got your answer
