Re: BB Aluminum intake question
[Re: floridian]
#1573634
02/03/14 05:48 PM
02/03/14 05:48 PM
Posts: 43,237 Bend,OR USA
Cab_Burge
Most of the early Mopar inatke manifolds for BB V8 did not come with any provisions to mount a bracket to hold the kickdown linkage the pivot, if it was a three piece kickdown set up, was on the throttle cable bracket IHTHs, BTW a Lokar cable set up may be your best and only choice if you don't want to make a brqcket for your kickdown linkage. What size and year motor are you working on?
[Re: floridian]
#1573635
02/03/14 06:22 PM
02/03/14 06:22 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
So where do I bolt my kickdown linkage on an aftermarket aluminum intake with NO mounting area for it?? Are there any brackets made for this?? I can't seem to find anything.. Thanks for any help here..
A picture of the linkage you are using and/or a description of the linkage would be helpful .
[Re: JohnRR]
#1573636
02/04/14 11:41 AM
02/04/14 11:41 AM
Posts: 1,574 Lakeland FL
floridian
Lakeland FL
Good point John, Car in the pic using the stock kickdown linkage that came in the 67 coronet.. rods and belcranks.. I have seen a bracket for sale that mounts under the carb, but I believe that its only for the throttle cable.. I guess this intake is for manual transmissions only??
[Re: Cab_Burge]
#1573637
02/04/14 11:43 AM
02/04/14 11:43 AM
floridian
Lakeland FL
67 coronet, stock 440/727... Not really interested in using a Lokar after market K/D linkage...
[Re: floridian]
#1573639
02/04/14 02:36 PM
02/04/14 02:36 PM
JohnRR
U.S.S.A.
If you are using the stock linkage now it doesn't bolt to the intake ???
Since you have a 440 already how is it currently connected ? What intake are you swapping to and what carb are you running ???
[Re: roadhazard]
#1573641
02/04/14 02:46 PM
02/04/14 02:46 PM
JohnRR
U.S.S.A.
As Mr Yuck said. The two rearmost intake bolts on the drivers side hold the bracket.
that's the 1 piece linkage , he has the 3 piece , but it's the same concept of how it bolts on , last intake bolt holds the bracket. This is what he should currently have .
[Re: JohnRR]
#1573642
02/07/14 02:42 PM
02/07/14 02:42 PM
floridian
Lakeland FL
Based on my memory that pic is the correct bracket but it bolts into the same hole as the throttle cable bracket does, as in the above pic with the incorrect 1pc linkage NOT to the intake to head bolts. Do any Aluminum intakes come with this or do I need to purchase the aftermarket bracket from the second poster??
[Re: floridian]
#1573645
02/08/14 01:43 PM
02/08/14 01:43 PM
JohnRR
U.S.S.A.
NO the throttle cable AND the kickdown linkage both bolt to the EXACT SAME BRACKET, see that silver clamp on top , that's where the throttle cable goes USE WHAT YOU CURRENTLY HAVE .... there is no big block intake ... except the 440 6pk and maybe the Max Wedge dual quad ... where any bracket bolts to the intake itself ... the picture with the 1 piece linkage also use a bracket that bolts to the engine by way of the intake bolts, it uses 2 instead of 1 and the throttle linkage bolts to it also.
[Re: JohnRR]
#1573647
02/10/14 11:38 AM
02/10/14 11:38 AM
floridian
Lakeland FL
If you haven't seen my other post the above comment by JohnRR is correct. My apologies for the wild goose chase here.. Too many Martini's at Manny's.......
[Re: floridian]
#1573648
02/10/14 05:40 PM
02/10/14 05:40 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Glad to know you got your answer
