Page 1 of 4 1 2 3 4
Tell me why I should or shouldn't #1570630
01/29/14 03:15 PM
01/29/14 03:15 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I'm going to get started on the NOS install this weekend (if I can get a few hours) and wonder why I should or shouldn't hang the bottle under my dash.
Pros: Plenty of room, shorter line, hidden, easy to turn on an off
Cons: it's in the car, it's somewhat awkeward to hang....
Coming soon!!!!
Re: Tell me why I should or shouldn't [Re: Mr.Yuck] #1570631
01/29/14 03:39 PM
01/29/14 03:39 PM
ohio
67mprfan Online content
67mprfan  Online Content
ohio
I think another con would be heating the bottle or keeping it warm
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Tell me why I should or shouldn't [Re: Mr.Yuck] #1570632
01/29/14 03:40 PM
01/29/14 03:40 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
I wouldn't do it because you have a pressurized container, ie bomb, in the car. Put it in the trunk with a remote switch.
Re: Tell me why I should or shouldn't [Re: Mr.Yuck] #1570633
01/29/14 03:40 PM
01/29/14 03:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
For one thing... the bottle needs to be point in the
proper direction... and from what you are saying I
would think you are putting it in sideways which is
wrong....JMO... since I'm not a nitrous guy
Re: Tell me why I should or shouldn't [Re: MR_P_BODY] #1570634
01/29/14 03:45 PM
01/29/14 03:45 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Bottles will work sideways if they are rotated the right way.
It will be more difficult to swap bottles, a track official may not be able to kill the bottle in case of an accident. Just a couple thoughts
Re: Tell me why I should or shouldn't [Re: SpareParts] #1570635
01/29/14 03:50 PM
01/29/14 03:50 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Hard to get too. Where are you putting pressure guage? How are you going to heat it?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Tell me why I should or shouldn't [Re: SpareParts] #1570636
01/29/14 03:55 PM
01/29/14 03:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I know they have a pickup tube inside and in most
cases laying on its side wasnt the best way to get
the max amount out of the bottle... the tube basically
goes to the bottom corner of the bottle... I have a
couple of kits and bottles and I know I would never
mount the bottle laying on its side
Re: Tell me why I should or shouldn't [Re: MR_P_BODY] #1570637
01/29/14 04:06 PM
01/29/14 04:06 PM
Guitar Jones Offline
Man how many cars have I seen with the bottle mounted to the right floor? Quite a few.
Re: Tell me why I should or shouldn't [Re: Mr.Yuck] #1570638
01/29/14 04:22 PM
01/29/14 04:22 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Unless its a 5lb bottle, I wouldn't.
Changing the bottle would be a complete pain. Go through all the effort of hiding it, only to spend 20 minutes under the dash at the track to swap the bottle out...
Also mounting weight high and up front...
If it is truly under the dash, not sure how easy it will be to turn it off, I would run a seperate 1/4 turn that you can access strapped in, just in case.
I mounted mine behind the seat, with a black bottle blanket you really have to look for it.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Tell me why I should or shouldn't [Re: Mr.Yuck] #1570639
01/29/14 04:43 PM
01/29/14 04:43 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Build a badder motor then you won`t need that stuff.............. That`s for the cowl hood comment.........but seriously, that seems scarry to me having an explosive missle anywhere in the car but as stated guys have been doin it for years.
Re: Tell me why I should or shouldn't [Re: Thumperdart] #1570640
01/29/14 05:33 PM
01/29/14 05:33 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I don't have anything under the dash. no nothing. I can open the glove box door and get to it. It would be mounted sideways, and while it wouldn't be as easy as the trunk it could be done in 5-10 minutes. Also how is it easier to turn off in the trunk? I have a lock and key. Heat? I only run in nice weather and that area gets warm as I don't have firewall insolation. How hot does it need to be? I see tons of bottles in the car, even on the floor. A lot of guys here don't even use a blanket or heater. It would be sideways but I think I can make it work. It won't be used all the time, maybe once or twice a race weekend. Maybe more if I want to run the 6.50 1/8 mile index or 10.50 1/4 index. I'm only going to run a 100-150 shot.
Next motor will be badder, just having fun w/ this one. As I understand it it's an oxidizer and not flammable. It will have a full range of safety stuff, on/off, WOT switch and so on.
Somebody said pressure gauge, I can see it thru the glove box door, or just peak under the dash depending.
Re: Tell me why I should or shouldn't [Re: Mr.Yuck] #1570641
01/29/14 06:21 PM
01/29/14 06:21 PM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
look at the bright side,if you crash and nobody can get to it,you wont feel a thing while youre choking on your own puke from the anti inhalation additive.................is that colorfull enough for you?
SFI 25.5 depends,no leak,even at 213 mph....
Re: Tell me why I should or shouldn't [Re: Mr.Yuck] #1570642
01/29/14 06:29 PM
01/29/14 06:29 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
If you can't run those times without NOS you need another engine builder.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Tell me why I should or shouldn't [Re: pittsburghracer] #1570643
01/29/14 06:32 PM
01/29/14 06:32 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Read my above post..............
Re: Tell me why I should or shouldn't [Re: Thumperdart] #1570644
01/29/14 06:36 PM
01/29/14 06:36 PM
PA.
"Little"John
"Little"John
PA.
I caught that. I just wanted to 2nd the motion.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Tell me why I should or shouldn't [Re: pittsburghracer] #1570645
01/29/14 07:11 PM
01/29/14 07:11 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
One thing to consider, I've seen a car with a bottle (my brother's) after an accident, I wouldn't guarantee the bottle brackets are going to prevent the bottle from becoming a projectile. This could go bad
Re: Tell me why I should or shouldn't [Re: SpareParts] #1570646
01/29/14 07:20 PM
01/29/14 07:20 PM
Delray beach, Florida
P
Performance Only Offline
P
I hope we never have to say something like;
"we all tried to warn him about that, we'll miss him around here". or, " We hope your recovery goes as planned".
machine shop owner and engine builder
Re: Tell me why I should or shouldn't [Re: Thumperdart] #1570647
01/29/14 07:46 PM
01/29/14 07:46 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
This engine is probably good for 10's but I'd have to swap out the 6-pack, go with more gear and convert. No thanks I DRIVE it. Also consider it's no a gutted out A-body. Anybody can make those fast. I'm guessing w/ the Cal-Trac & mono spring It should be around 11.0 w/o the bottle. I guess that's real slow.
Re: Tell me why I should or shouldn't [Re: Mr.Yuck] #1570648
01/29/14 08:39 PM
01/29/14 08:39 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You`re a fuuny guy........"anybody can make those fast" Ya, I see 9-second 3200 lbs.(at the time of my 9.79)driving around everyday..............and I drive my car all over but hey, thankxxx 4 the compliment..............
Re: Tell me why I should or shouldn't [Re: Mr.Yuck] #1570649
01/29/14 08:43 PM
01/29/14 08:43 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Heat? I only run in nice weather and that area gets warm as I don't have firewall insolation. How hot does it need to be As I understand it it's an oxidizer and not flammable
So you say your only going to run it in nice weather. And it gets warm in that Firewall area.
That tanks highly pressurised and blow up with too much heat.
To be convinced not to do it, Google "Nitrous tank explosions" Take a look at some of the Multible images.
Page 1 of 4 1 2 3 4
