1973 440/727 Torque Converter
#1566322
01/21/14 10:49 AM
01/21/14 10:49 AM
Posts: 173 PA
RoadRunner73
PA
I bought a 440 and 727 at Carlise this past year and the Tranny is in the shop getting worked over now. Got a call back from them because the torque converter didn't have any balancers on it which from what I'm finding can't be right for the engine and tranny... looking to figure out what crank I have in the engine to really solve the problem, whats the best way (besides ripping it apart) to find this out? The engine is going to be rebuilt soon but going to stay pretty well stock...
----- 1973 Plymouth Road Runner
Re: 1973 440/727 Torque Converter
[Re: RoadRunner73]
#1566324
01/21/14 10:56 AM
01/21/14 10:56 AM
Posts: 1,795 Greer, SC
TooMany62s
Greer, SC
Normally if you have a thick balancer like the one on the left it's a cast crank. If you have a thin balancer like the one on the right you have a forged crank. Of course that assumes the motor has the right balancer on it.
[Re: Dan Halen]
#1566326
01/21/14 11:38 AM
01/21/14 11:38 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
if we trust on what factory should do... 73 440 autos should be cast so you'll need counterweights on TC
73 440 manuals got forged
[Re: NachoRT74]
#1566327
01/21/14 11:41 AM
01/21/14 11:41 AM
Posts: 173 PA
RoadRunner73
PA
I've seen this but I've also seen variation. The other thing is I dont know if this engines been taken apart and if anything has been changed on it or not.
[Re: Dan Halen]
#1566329
01/21/14 04:24 PM
01/21/14 04:24 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Pull the pan and look for the parting line on the crank. A thin line indicates a cast crank, thicker line is forged which would have no weights on the converter.
Yep...
I.D. the crank POSITIVELY, and go from there...
[Re: Polarapete]
#1566333
01/21/14 10:27 PM
01/21/14 10:27 PM
Posts: 156 bc
37dodge
bc
[Re: Yellow Fever]
#1566336
01/21/14 11:29 PM
01/21/14 11:29 PM
Posts: 173 PA
RoadRunner73
PA
I'll have to look its in storage
[Re: RoadRunner73]
#1566338
01/22/14 04:20 PM
01/22/14 04:20 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
'73 was the first year of the cast 440 crank, all 440HP were supposed to have forged but standard 440 could have either cast or forged at random.
[Re: John_Kunkel]
#1566339
01/22/14 07:35 PM
01/22/14 07:35 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
One thing that we are all overlooking in this thread is that the OP said he bought the engine and trans @ Carlisle swap meet. Now if it was an OEM assembly (ran well from the factory and had never been apart) then the fact that it had a converter with no balance weights would indicate a forged crank. At any rate, the transmission is being rebuilt and some time down the road the engine will be rebuilt. So continue with the transmission rebuild, rebuild the motor and put them together with a compatible converter whether it be the original or a replacement and you will be happy.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Yellow Fever]
#1566340
01/22/14 09:33 PM
01/22/14 09:33 PM
Posts: 167 maryland
74yellowduster
maryland
forged crank = neutral balanced flex plate, neutral torque converer, neutral balancer cast crank = offset balancer, and then stock was a neutral flex plate and wheighted torque converter in order to use a neutral (easy to buy) torque converter when using a cast crank setup, many use a B&M flex plate that has a bite out of it. so you can use cast crank , your offset balancer in the front, your offset B&M flex plate and a neutral torque converter note: you would not use a wheighted torque converter and an offset flexplate together. it's one or the other with a cast crank, not both
