1973 440/727 Torque Converter #1566322
01/21/14 10:49 AM
01/21/14 10:49 AM
PA
RoadRunner73 Offline OP
PA
I bought a 440 and 727 at Carlise this past year and the Tranny is in the shop getting worked over now. Got a call back from them because the torque converter didn't have any balancers on it which from what I'm finding can't be right for the engine and tranny... looking to figure out what crank I have in the engine to really solve the problem, whats the best way (besides ripping it apart) to find this out? The engine is going to be rebuilt soon but going to stay pretty well stock...
1973 Plymouth Road Runner
Re: 1973 440/727 Torque Converter [Re: RoadRunner73] #1566323
01/21/14 10:55 AM
01/21/14 10:55 AM
Plymouth, MI
HotRod20 Offline
HotRod20  Offline
Plymouth, MI
Look at your crank balancer. For a cast crank engine,It will be thicker and have an offset counter balance on the front of it.The forged crank balancers are thinner in design. Obtain a service manual or go online for pictures to compare the two. HR20
Re: 1973 440/727 Torque Converter [Re: RoadRunner73] #1566324
01/21/14 10:56 AM
01/21/14 10:56 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Normally if you have a thick balancer like the one on the left it's a cast crank. If you have a thin balancer like the one on the right you have a forged crank. Of course that assumes the motor has the right balancer on it.
Re: 1973 440/727 Torque Converter [Re: RoadRunner73] #1566325
01/21/14 11:10 AM
01/21/14 11:10 AM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
Pull the pan and look for the parting line on the crank. A thin line indicates a cast crank, thicker line is forged which would have no weights on the converter.
Re: 1973 440/727 Torque Converter [Re: Dan Halen] #1566326
01/21/14 11:38 AM
01/21/14 11:38 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
if we trust on what factory should do... 73 440 autos should be cast so you'll need counterweights on TC
73 440 manuals got forged
Re: 1973 440/727 Torque Converter [Re: NachoRT74] #1566327
01/21/14 11:41 AM
01/21/14 11:41 AM
PA
PA
I've seen this but I've also seen variation. The other thing is I dont know if this engines been taken apart and if anything has been changed on it or not.
Re: 1973 440/727 Torque Converter [Re: RoadRunner73] #1566328
01/21/14 03:19 PM
01/21/14 03:19 PM
Beans Cove Pa
Bumbalawski Offline
Bumbalawski  Offline
Beans Cove Pa
The dampener will tell it all. The 73 and 74 HP 440 engines had forged cranks, at least the ones I have found. If the dampener is not weighted, it is a forged crank and does not need weights on the torque convertor.
Re: 1973 440/727 Torque Converter [Re: Dan Halen] #1566329
01/21/14 04:24 PM
01/21/14 04:24 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Yep...
I.D. the crank POSITIVELY, and go from there...
Re: 1973 440/727 Torque Converter [Re: RSNOMO] #1566330
01/21/14 05:57 PM
01/21/14 05:57 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
A friend once told me that "Chrysler made their forged cranks with a rotary axe" and it is pretty obvious what a forged crank looks like compared to a cast version of course the OEM cast models are smaller, lighter and cleaner looking than the OEM forged units and because of that they require external balancing. Now the spendy aftermarket forged pieces are a lot nicer, but they are also at least 40 years newer. Build your motor around the crank and you won't go wrong
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 1973 440/727 Torque Converter [Re: Polarapete] #1566331
01/21/14 06:11 PM
01/21/14 06:11 PM
bc
3
37dodge Offline
37dodge  Offline
bc
http://www.moparts.org/Tech/Archive/bb/22.html
there is a pic of the two cranks on here same place to.
Re: 1973 440/727 Torque Converter [Re: 37dodge] #1566332
01/21/14 08:55 PM
01/21/14 08:55 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I still think you are better off to dig deeper into the motor and check the crank. A balancer does not know what it is bolted to and it is possible that an unscrupulous person could throw together a long block with a "Krylon" rebuild and and tout it as something special. But, none of us would do such a thing
2008 Honda Element
Re: 1973 440/727 Torque Converter [Re: Polarapete] #1566333
01/21/14 10:27 PM
01/21/14 10:27 PM
bc
3
37dodge Offline
37dodge  Offline
bc
Re: 1973 440/727 Torque Converter [Re: 37dodge] #1566334
01/21/14 10:30 PM
01/21/14 10:30 PM
PA
PA
Thanks this should help
Re: 1973 440/727 Torque Converter [Re: RoadRunner73] #1566335
01/21/14 10:41 PM
01/21/14 10:41 PM
SE PA
Yellow Fever Offline
SE PA
What does the flexplate look like? Factory?
Re: 1973 440/727 Torque Converter [Re: Yellow Fever] #1566336
01/21/14 11:29 PM
01/21/14 11:29 PM
PA
PA
I'll have to look its in storage
Re: 1973 440/727 Torque Converter [Re: RoadRunner73] #1566337
01/21/14 11:54 PM
01/21/14 11:54 PM
SE PA
SE PA
It could have had a weighted flexplate on it and a neutral torque convertor.
Re: 1973 440/727 Torque Converter [Re: RoadRunner73] #1566338
01/22/14 04:20 PM
01/22/14 04:20 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
'73 was the first year of the cast 440 crank, all 440HP were supposed to have forged but standard 440 could have either cast or forged at random.
Re: 1973 440/727 Torque Converter [Re: John_Kunkel] #1566339
01/22/14 07:35 PM
01/22/14 07:35 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
One thing that we are all overlooking in this thread is that the OP said he bought the engine and trans @ Carlisle swap meet. Now if it was an OEM assembly (ran well from the factory and had never been apart) then the fact that it had a converter with no balance weights would indicate a forged crank. At any rate, the transmission is being rebuilt and some time down the road the engine will be rebuilt. So continue with the transmission rebuild, rebuild the motor and put them together with a compatible converter whether it be the original or a replacement and you will be happy.
2008 Honda Element
Re: 1973 440/727 Torque Converter [Re: Yellow Fever] #1566340
01/22/14 09:33 PM
01/22/14 09:33 PM
maryland
74yellowduster Offline
maryland
forged crank = neutral balanced flex plate, neutral torque converer, neutral balancer
cast crank = offset balancer, and then stock was a neutral flex plate and wheighted torque converter
in order to use a neutral (easy to buy) torque converter when using a cast crank setup, many use a B&M flex plate that has a bite out of it.
so you can use cast crank , your offset balancer in the front, your offset B&M flex plate and a neutral torque converter
note: you would not use a wheighted torque converter and an offset flexplate together. it's one or the other with a cast crank, not both
Re: 1973 440/727 Torque Converter [Re: Polarapete] #1566341
01/22/14 11:07 PM
01/22/14 11:07 PM
PA
PA
This exactly what my plan is, made the decision tonight to just hold off on the torque converter cinch the engine will be done in the near future. Once the engine is done I'll have the needed info to purchase the converter.
