E-body Floor Pan Seat Mounting Reinforcement Brackets? #1566044
01/20/14 05:40 PM
01/20/14 05:40 PM
California, USA
filmsurgeon Offline OP
California, USA
Did all E-bodies have these inboard brackets/braces on the underside of the floor pans (see red circled areas in photos)? My '70 Challenger Convertible does not have them, but the outboard brackets/braces ARE there, and I believe the floor pans are original, but not 100% certain. If all E-bodies had them, does anyone know if these are being reproduced? Were the welded in? Thanks
Re: E-body Floor Pan Seat Mounting Reinforcement Brackets? [Re: filmsurgeon] #1566045
01/20/14 10:01 PM
01/20/14 10:01 PM
Virginia
larry4406 Online content
larry4406  Online Content
Virginia
My 71 barracuda vert has the seat brackets. My car had bucket seats from the factory. There is a similar thread from the same OP on cuda-challenger and a reply there says no brackets on bench seat cars.
Re: E-body Floor Pan Seat Mounting Reinforcement Brackets? [Re: larry4406] #1566046
01/20/14 10:05 PM
01/20/14 10:05 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
You smarter guys correct me if I am wrong, but I bet a car that was originallyn equipped with a bench seat would not have had them..... and yes, welded in.
jess
Yeah, it's hopped up to over 160...
Re: E-body Floor Pan Seat Mounting Reinforcement Brackets? [Re: jt4406] #1566047
01/20/14 10:22 PM
01/20/14 10:22 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
jess
Correct Jess, the benchseat E bodies would not have the inner seat bolt re-enforcement plates, only bucket seat cars
Mike
Re: E-body Floor Pan Seat Mounting Reinforcement Brackets? [Re: DAYCLONA] #1566048
01/20/14 10:35 PM
01/20/14 10:35 PM
Sacramento,California
JRepucci Offline
JRepucci  Offline
No bench seat convertibles. Not an option.
Re: E-body Floor Pan Seat Mounting Reinforcement Brackets? [Re: JRepucci] #1566049
01/20/14 10:39 PM
01/20/14 10:39 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I'd beg to differ with you, as I changed out a 71 Challenger benchseat/column shift convertible to buckets back in the 80's
Re: E-body Floor Pan Seat Mounting Reinforcement Brackets? [Re: DAYCLONA] #1566050
01/20/14 10:55 PM
01/20/14 10:55 PM
JRepucci Offline
JRepucci  Offline
1970 Plymouth Car and Equipment prices "Barracuda"
Re: E-body Floor Pan Seat Mounting Reinforcement Brackets? [Re: JRepucci] #1566051
01/20/14 11:18 PM
01/20/14 11:18 PM
california
Mr D21 Offline
Mr D21  Offline
california
Hey Jason - did Dodge offer bench seat for convt ?
Re: E-body Floor Pan Seat Mounting Reinforcement Brackets? [Re: Mr D21] #1566052
01/20/14 11:45 PM
01/20/14 11:45 PM
GEORGIA
barracuda7199 Offline
GEORGIA
my 71 barracuda factory bench seat car has all 8 brackets. im getting ready to replace the floor pan now and have to reuse the factory ones.
Re: E-body Floor Pan Seat Mounting Reinforcement Brackets? [Re: barracuda7199] #1566053
01/21/14 03:40 PM
01/21/14 03:40 PM
California, USA
California, USA
Thanks for the responses guys. Just spoke with AMD this morning. They do not have a part # for these pieces (plates), as they receive the floor pans with braces attached. However, the guy I spoke to took my name and number and said he'd look into it and get back to me. Keeping my fingers crossed, but pretty sure they won't be able to help me out.
Re: E-body Floor Pan Seat Mounting Reinforcement Brackets? [Re: filmsurgeon] #1566054
01/21/14 03:50 PM
01/21/14 03:50 PM
Boston, MA
crocha617 Offline
crocha617  Offline
Boston, MA
Those pieces are not attached to the floor pans from AMD. They come loose in the box. At the last couple I bought did.
Re: E-body Floor Pan Seat Mounting Reinforcement Brackets? [Re: crocha617] #1566055
01/21/14 05:17 PM
01/21/14 05:17 PM
California, USA
California, USA
Interesting. The guy at AMD certainly didn't seem to be aware of that, unless he just didn't want to disclose it. So, I presume then that it is up to the purchaser to attach them to the floor pan. Do they get spot welded in? I assume they could also be attached via sheet metal screws, or nuts/bolts, but that would require drilling into the plates and the floor pan.
Re: E-body Floor Pan Seat Mounting Reinforcement Brackets? [Re: filmsurgeon] #1566056
01/21/14 06:13 PM
01/21/14 06:13 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
they were wire welded to the floor,
just like some of the 4 speed humps were done.
somebody out there makes them if they came in a box,
it just takes some good searching around to find the source.
i would ask jeff at 521 restorations
he deals with all of the major mopar metal vendors
amd,goodmark,dynacorn.. ect
i'd bet he would know if they are out there..
Re: E-body Floor Pan Seat Mounting Reinforcement Brackets? [Re: filmsurgeon] #1566057
01/21/14 09:46 PM
01/21/14 09:46 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I've seen them on e bay from time to time. And reproductions to.
Re: E-body Floor Pan Seat Mounting Reinforcement Brackets? [Re: crocha617] #1566058
01/21/14 10:24 PM
01/21/14 10:24 PM
GEORGIA
GEORGIA
My AMD floor pan doesn't have them attached to it or the seat belt braces. I got the pan second hand so I can't say what was in the box.
Re: E-body Floor Pan Seat Mounting Reinforcement Brackets? [Re: barracuda7199] #1566059
01/22/14 02:50 AM
01/22/14 02:50 AM
KY USA
mopargem Offline
mopargem  Offline
KY USA
If you dont have access to or dont want to weld them, I dont see why you couldnt just sandwich them between the floor pan and the captive washer nut that goes on the seat stud. Once tightened they arnt going anywhere. They are basically a jumbo washer.
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: E-body Floor Pan Seat Mounting Reinforcement Brackets? [Re: mopargem] #1566060
01/22/14 04:03 PM
01/22/14 04:03 PM
California, USA
California, USA
Thanks. I considered just holding them in place with the large captive washer nut, but would probably end up securing each of the 4 corners with short bolts with nuts, or sheet metal screws. I just need to get a set so I can decide how to proceed.
Re: E-body Floor Pan Seat Mounting Reinforcement Brackets? [Re: filmsurgeon] #1566061
01/31/14 06:17 PM
01/31/14 06:17 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
Would these work?
Jess
