Re: E-body Floor Pan Seat Mounting Reinforcement Brackets?
[Re: filmsurgeon]
#1566045
01/20/14 10:01 PM
01/20/14 10:01 PM
Posts: 521 Virginia
larry4406
Virginia
My 71 barracuda vert has the seat brackets. My car had bucket seats from the factory. There is a similar thread from the same OP on cuda-challenger and a reply there says no brackets on bench seat cars.
[Re: larry4406]
#1566046
01/20/14 10:05 PM
01/20/14 10:05 PM
Posts: 1,567 Ky
jt4406
Ky
You smarter guys correct me if I am wrong, but I bet a car that was originallyn equipped with a bench seat would not have had them..... and yes, welded in. jess
Yeah, it's hopped up to over 160...
[Re: jt4406]
#1566047
01/20/14 10:22 PM
01/20/14 10:22 PM
Posts: 18,157 Mass
DAYCLONA
Mass
jess
Correct Jess, the benchseat E bodies would not have the inner seat bolt re-enforcement plates, only bucket seat cars
Mike
[Re: JRepucci]
#1566049
01/20/14 10:39 PM
01/20/14 10:39 PM
Posts: 18,157 Mass
DAYCLONA
Mass
No bench seat convertibles. Not an option.
I'd beg to differ with you, as I changed out a 71 Challenger benchseat/column shift convertible to buckets back in the 80's
[Re: crocha617]
#1566055
01/21/14 05:17 PM
01/21/14 05:17 PM
Posts: 401 California, USA
filmsurgeon
California, USA
Those pieces are not attached to the floor pans from AMD. They come loose in the box. At the last couple I bought did.
Interesting. The guy at AMD certainly didn't seem to be aware of that, unless he just didn't want to disclose it. So, I presume then that it is up to the purchaser to attach them to the floor pan. Do they get spot welded in? I assume they could also be attached via sheet metal screws, or nuts/bolts, but that would require drilling into the plates and the floor pan.
[Re: filmsurgeon]
#1566056
01/21/14 06:13 PM
01/21/14 06:13 PM
Posts: 18,632 jersey shore
flypaper
I hate Texas
I hate Texas
jersey shore
they were wire welded to the floor, just like some of the 4 speed humps were done. somebody out there makes them if they came in a box, it just takes some good searching around to find the source. i would ask jeff at 521 restorations he deals with all of the major mopar metal vendors amd,goodmark,dynacorn.. ect i'd bet he would know if they are out there..
[Re: barracuda7199]
#1566059
01/22/14 02:50 AM
01/22/14 02:50 AM
Posts: 3,379 KY USA
mopargem
KY USA
If you dont have access to or dont want to weld them, I dont see why you couldnt just sandwich them between the floor pan and the captive washer nut that goes on the seat stud. Once tightened they arnt going anywhere. They are basically a jumbo washer.
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F6 M6W 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
[Re: mopargem]
#1566060
01/22/14 04:03 PM
01/22/14 04:03 PM
filmsurgeon
California, USA
Thanks. I considered just holding them in place with the large captive washer nut, but would probably end up securing each of the 4 corners with short bolts with nuts, or sheet metal screws. I just need to get a set so I can decide how to proceed.
