Good quality small block timing chain? #1565285
01/19/14 12:14 AM
01/19/14 12:14 AM
B.C.
mk_ Offline OP
mk_  Offline OP
B.C.
Any input on a great quality timing chain set for a 340?
Will a true roller with steel gears last longer?
Re: Good quality small block timing chain? [Re: mk_] #1565286
01/19/14 12:46 AM
01/19/14 12:46 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
#1 Cloyes
#2 Yes
I am truckless..
Re: Good quality small block timing chain? [Re: 340SHORTY] #1565287
01/19/14 02:08 AM
01/19/14 02:08 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Last set of Cloyes I put on my 360 stretched out in about 20k miles. It was a stock replacement type though. I love the Edelbrock timing sets and run those now.
Don't be the exception.
Re: Good quality small block timing chain? [Re: Supercuda] #1565288
01/19/14 02:36 AM
01/19/14 02:36 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
last cloyes I bought ...it was a billet set..the chain broke while idling ...and bent 5 valves...and a bunch more pushrods.
Tony
70 AARCuda Vitamin C
Re: Good quality small block timing chain? [Re: 70AARcuda] #1565289
01/19/14 03:38 AM
01/19/14 03:38 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I had that happen with a "Summit" brand timing chain. The 67 Dart was idling to warm up, then just shut off like I pulled the coil wire or something. It bent 4 pushrods and even though I replaced them, I still hear a ticking sound at idle. maybe it has a bent valve or two, though the idle isn't any rougher than before.
Re: Good quality small block timing chain? [Re: Kern Dog] #1565290
01/19/14 05:17 AM
01/19/14 05:17 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Last Summit brand I bought was made by ... Cloyes.
Re: Good quality small block timing chain? [Re: Supercuda] #1565291
01/19/14 08:13 AM
01/19/14 08:13 AM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
That's odd, last Cloyes I bought for my 340 was a double roller, had no problems with it.
-Daty
Re: Good quality small block timing chain? [Re: mk_] #1565292
01/19/14 01:35 PM
01/19/14 01:35 PM
I had a Summitt house brand (for a SB) ten years ago & it was a sloppy fit brand new
Re: Good quality small block timing chain? [Re: RapidRobert] #1565293
01/19/14 02:10 PM
01/19/14 02:10 PM
Il
1ol74charger4me Offline
Il
Summit lists a Cloyes street roller for $58 and the true roller for $150ish. Is there really $100 difference in the 2? Can't find anything in the description to base it on. Surprised to see the problems people have had with them. I always thought a Cloyes was a "put in and forget about" kinda part.
Re: Good quality small block timing chain? [Re: 1ol74charger4me] #1565294
01/19/14 02:19 PM
01/19/14 02:19 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
As I said, my Cloyes stuff was stock replacement types, not roller, double roller or whatever.
Never tried that stuff from Cloyes because it was my DD.
Re: Good quality small block timing chain? [Re: Supercuda] #1565295
01/20/14 12:43 AM
01/20/14 12:43 AM
B.C.
mk_ Offline OP
mk_  Offline OP
B.C.
Thanks for the info........another brand i just read up on and may try is the Progear chain sets.
Re: Good quality small block timing chain? [Re: mk_] #1565296
01/20/14 01:31 AM
01/20/14 01:31 AM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
And should install a tensioner too.
Facts are stubborn things.
Re: Good quality small block timing chain? [Re: larrymopar360] #1565297
01/20/14 09:32 AM
01/20/14 09:32 AM
IN
ahy Offline
ahy  Offline
IN
I've had good luck with a Cloyes "true roller" on a BB. The more expensive one. I did have to buy a -.010" version to get it good and tight with my align bored block.
On a SB, I believe the tensioner requires a stock style chain. Hi po "true roller" types tear up the tensioner. It wouldn't hurt to price a stock replacement chain from your local dealer. I "think" length was the same through the years so a replacement magnum chain should work. That has proven to be a durable piece.
Hope others will confirm the fit.
Re: Good quality small block timing chain? [Re: mk_] #1565298
01/20/14 02:17 PM
01/20/14 02:17 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
This is the way to go. I have sold and used 100's of sets, and they dont stretch and wear like many of the others. Good true old school American quality stuff, from a company that has been making gears for many many years.
Cloyes is simply not the quality it used to be. I dont use anything Cloyes, unless a customer already has their own to supply for the build. Not impressed.
Most all " big box" and cam manufacter brands are just reboxed sets made by one of basically 3 or 4 companies.Also dont be fooled by " billet" timing sets either. It doesnt always meant hey are the best choice. You will often find the chains on some sets wear first, and on other cheap sets, the teeth simply wear down quickly. A set is also not necessarily good because it " looks nice" ( IE: some of the billet stuff).
RIP Monte Smith
Re: Good quality small block timing chain? [Re: CompWedgeEngines] #1565299
01/21/14 06:44 AM
01/21/14 06:44 AM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
So, this would be the ProGear to go with: http://r.ebay.com/Map9CZ
Still Made in the USA as well...
Re: Good quality small block timing chain? [Re: 1972CudaV21] #1565300
01/21/14 01:49 PM
01/21/14 01:49 PM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
Cloyes double roller is all I've ever run in my HP strokers. No problems. But I'm sure everybody has some other opinions on this.
But, you know what they say about opinions. Opinions are a$$ holes everyone has one, and they usually stink!
Re: Good quality small block timing chain? [Re: bigblock340power] #1565301
01/22/14 01:27 PM
01/22/14 01:27 PM
crlush Offline
crlush  Offline
Bought a summit timing set once and the chain had so much slack I sent it back and put the old one back on.
