Re: Good quality small block timing chain?
[Re: mk_]
#1565286
01/19/14 12:46 AM
01/19/14 12:46 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
#1 Cloyes #2 Yes
I am truckless..
[Re: 340SHORTY]
#1565287
01/19/14 02:08 AM
01/19/14 02:08 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Last set of Cloyes I put on my 360 stretched out in about 20k miles. It was a stock replacement type though. I love the Edelbrock timing sets and run those now.
[Re: Supercuda]
#1565288
01/19/14 02:36 AM
01/19/14 02:36 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
last cloyes I bought ...it was a billet set..the chain broke while idling ...and bent 5 valves...and a bunch more pushrods.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: mk_]
#1565292
01/19/14 01:35 PM
01/19/14 01:35 PM
RapidRobert
I had a Summitt house brand (for a SB) ten years ago & it was a sloppy fit brand new
[Re: mk_]
#1565296
01/20/14 01:31 AM
01/20/14 01:31 AM
Posts: 15,827 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
And should install a tensioner too.
Facts are stubborn things.
[Re: mk_]
#1565298
01/20/14 02:17 PM
01/20/14 02:17 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Thanks for the info........another brand i just read up on and may try is the Progear chain sets.
This is the way to go. I have sold and used 100's of sets, and they dont stretch and wear like many of the others. Good true old school American quality stuff, from a company that has been making gears for many many years.
Cloyes is simply not the quality it used to be. I dont use anything Cloyes, unless a customer already has their own to supply for the build. Not impressed.
Most all " big box" and cam manufacter brands are just reboxed sets made by one of basically 3 or 4 companies.Also dont be fooled by " billet" timing sets either. It doesnt always meant hey are the best choice. You will often find the chains on some sets wear first, and on other cheap sets, the teeth simply wear down quickly. A set is also not necessarily good because it " looks nice" ( IE: some of the billet stuff).
RIP Monte Smith
