T-56 and hydraulic clutch #1563181
01/14/14 03:12 PM
01/14/14 03:12 PM
Texas, Dallas
G_T Offline OP
G_T  Offline OP
Texas, Dallas
Debatable if this topic goes here or Q&A, but since most of the handling/pro-touring folks lurk here...
Situation: I have a Viper V10 in a b-body with the stock 4-spd pedal setup. The T-56 comes with a hydraulic throwout bearing. Unfortunately, I can not use the viper-truck clutch master cylinder/linkages (just wont fit).
What I am looking for, are examples that y'all have used to install either piece part (or kit preferrably) a hydraulic master cylinder.
I have found kits from American Power-train...and Kiesler... looking if anybody used these. Unfortunately these "kits" are $$$.
I've also seen people use wilwood 7/8" master cylinders/etc. and I assume they are engineering out the various linkages to the pedals.
So folks - what have you seen/done and do you have pictures and part #'s? What's worked well and what hasn't?
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com 2012 Charger SRT8
Re: T-56 and hydraulic clutch [Re: G_T] #1563182
01/14/14 03:33 PM
01/14/14 03:33 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Not a Mopar...but I made my own setup when I put the LS1/T56 in my Holden. I used a 3/4" master cylinder on mine (It was an OE master off some other GM) and found a long push rod for the master and cut the end off (it was an OE application as well from some other model) and a few inches longer than needed) and just threaded the end and screwed a rod end on that attached to the clutch pedal.
I just measured up the original pedal ratio from the Camaro donor (you could do the same with a Viper pedal) to get the right amount of throw/feel to it.
Been on for a while now and drives great.
I wouldn't hesitate to make my own setup again..Mopar or other wise. A clutch master is not all that pricey to start with.
I did make up a hose was all that had the funky quick connect on the throwout bearing end (does the Viper one use that too?) and just a normal AN fitting on the other end to get the length I wanted)
Re: T-56 and hydraulic clutch [Re: OzHemi] #1563183
01/14/14 03:42 PM
01/14/14 03:42 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
A pic in my case probably won't help you much
But for the heck of it..
I used an F body reservoir, and made my own mounting bracket for it (a T shape) and you can see the clutch master just to the right of it and slightly to the left/below the wiper motor...
Re: T-56 and hydraulic clutch [Re: OzHemi] #1563184
01/14/14 05:04 PM
01/14/14 05:04 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Here is mine, home fabbed. American Powertrain sells a nice $600 "bolt in" kit too.
Mopar to the bone!!!
Re: T-56 and hydraulic clutch [Re: 72Swinger] #1563185
01/14/14 05:05 PM
01/14/14 05:05 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Wilwood 7/8" bore seems to work lovely with Viper slave.
Re: T-56 and hydraulic clutch [Re: 72Swinger] #1563186
01/14/14 05:09 PM
01/14/14 05:09 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Ended up needing a braided brake line for packaging reasons.
Re: T-56 and hydraulic clutch [Re: 72Swinger] #1563187
01/14/14 05:25 PM
01/14/14 05:25 PM
Texas, Dallas
G_T Offline OP
G_T  Offline OP
Texas, Dallas
Awesome replies - just perfect. I can get the wilwood 7/8" master with ~1.1"-1.4" throw for like $75...
Oz - yeah i believe the viper has that funky quick disconnect deal... (Is your picture backwards? wrong side )
I'll see if i can snap a picture of the line connection - I anticipate that will be the biggest hassle. I like the AN fitting idea on one end.
Time to order parts and post an update in a month or so.
Re: T-56 and hydraulic clutch [Re: G_T] #1563188
01/14/14 05:32 PM
01/14/14 05:32 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
You can get a Russell -3 fitting at the slave cylinder to. Fitting sold under this part# http://www.summitracing.com/parts/rus-640281
Re: T-56 and hydraulic clutch [Re: 72Swinger] #1563189
01/14/14 05:43 PM
01/14/14 05:43 PM
Texas, Dallas
G_T Offline OP
G_T  Offline OP
Texas, Dallas
Awesome! That makes the problem easier. Gotta love amazon - picked up the wilwood master and that fitting above for $66/$18 respectively. Now i need the line (I will wait to measure that) and to mock up the bracket/etc. I like the hiem joint above - care to share any specifics on thread/etc?
Re: T-56 and hydraulic clutch [Re: G_T] #1563190
01/14/14 05:58 PM
01/14/14 05:58 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I went to my local circle track supply store and picked up the heim and the line. IIRC the heim is just a 1/4x3/8" female and line is a 36" -3 with a 90 on one end and a straight on the other, think it cost me $18.
Re: T-56 and hydraulic clutch [Re: 72Swinger] #1563191
01/14/14 06:01 PM
01/14/14 06:01 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Mine is along the same lines under the dash...
Re: T-56 and hydraulic clutch [Re: OzHemi] #1563192
01/14/14 06:02 PM
01/14/14 06:02 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Re: T-56 and hydraulic clutch [Re: 72Swinger] #1563193
01/14/14 06:05 PM
01/14/14 06:05 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I went to my local circle track supply store and picked up the heim ..
I got mine from Speedway Motors..they had a really nice selection. (Used them for all the ends I got to use on my adjustable sway bar end links as well)
And think mine was a 5/16 or 3/8? Would have to get under the dash and measure it, but the push rod on mine might be a different diameter than that wilwood one anyways..
I run ran a die over the rod and went with that size. (luckily it happened to be a handy outside diameter for the die as it was as well)
Re: T-56 and hydraulic clutch [Re: G_T] #1563194
01/14/14 06:11 PM
01/14/14 06:11 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
It is on the Right side actually.
Re: T-56 and hydraulic clutch [Re: OzHemi] #1563195
01/14/14 06:35 PM
01/14/14 06:35 PM
Texas, Dallas
G_T Offline OP
G_T  Offline OP
Texas, Dallas
Thanks guys - you've made this *easy* and saved me over $200 at least. I'll post pics when done.
Re: T-56 and hydraulic clutch [Re: G_T] #1563196
01/14/14 06:38 PM
01/14/14 06:38 PM
Cleveland, OH
fury413rb Offline
fury413rb  Offline
Cleveland, OH
I have a mcleod billet hydraulic throwout bearing. You may be able to use one to simplify the setup.
looks like this
Re: T-56 and hydraulic clutch [Re: OzHemi] #1563197
01/14/14 08:09 PM
01/14/14 08:09 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Yes, dont quote me on the size of the heim, the rod that comes with the Wilwood will determine that. It may be a 5/16x1/2".
Re: T-56 and hydraulic clutch [Re: 72Swinger] #1563198
01/15/14 01:50 AM
01/15/14 01:50 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
made my own bracket:
Re: T-56 and hydraulic clutch [Re: dangina] #1563199
01/15/14 07:29 AM
01/15/14 07:29 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Interesting. You have your master mounted inside the firewall.
I'm running a viper T56 in my Dakota. Using a stock Dakota master cylinder, stock SRT-10 truck hyd. TO bearing, and plumbing is handled with braided steel line and the russel fittings linked above.
Fits and works like the factory designed it that way
**Photobucket sucks**
Re: T-56 and hydraulic clutch [Re: 70Cuda383] #1563200
01/15/14 10:54 AM
01/15/14 10:54 AM
Wildwood, FL
1fastabody Offline
1fastabody  Offline
Wildwood, FL
Are you guys removing the return spring on the clutch pedal or using something different?
