Re: 67 B-body /6 to RB
[Re: Cab_Burge]
#1560672
01/08/14 12:09 PM
01/08/14 12:09 PM
Posts: 5,164 CT
GTX MATT
CT
V8 k frames are pretty easy to find and not expensive, I'd just get one.
[Re: Furious65]
#1560677
01/08/14 06:25 PM
01/08/14 06:25 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
Thanks gentlemen. So, I assume a stock manual gear box will swap between K-members?
Yes it will.
Also get a 68 or 69 B body K member and eliminate the $$$ stud mount idler arm while you are at it.
E body and 71/72 B body have a different steering box mounting angle , along with a different swaybar mounting setup so just stick with the 68/9 K .
[Re: Joesixpack]
#1560681
01/09/14 01:03 PM
01/09/14 01:03 PM
Posts: 11,912 APACHE JUNCTION AZ
Joesixpack
APACHE JUNCTION AZ
get your v8 k-frame and clean&paint or powder coat it when its bare...reinforce all welds...if you can...factory was sloppy and most of the stick arc welds were goobered up.
