Re: InLine Tubes?
[Re: JMCFAN]
#1558526
01/04/14 11:52 PM
01/04/14 11:52 PM
Posts: 1,822 Colorado
denfireguy
Colorado
Need to order brake and fuel lines as well as a gas tank. Looks line Inlinetubes.com has everything... and body have input?
used Inline for fuel, brake and transmission cooling lines. All fit perfectly. You did not list transmission cooling lines. If you have an automatic, you might want to change them too. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
Re: InLine Tubes?
[Re: weazel]
#1558529
01/06/14 12:59 PM
01/06/14 12:59 PM
As far as the lines go, I've had no problems with their lines. Their hold off/proportioning valves on the other hand I had numerous problems with! Even the replacements they sent me ended up acting like a one way valve and letting fluid go to the rear brakes but not back up to the master cylinder. Left me stranded a couple of times. Since then I have found an original and have had the original rebuilt.
