InLine Tubes? #1558522
01/04/14 01:04 PM
01/04/14 01:04 PM
New Mexico
JMCFAN Online content OP
JMCFAN  Online Content OP
New Mexico
Need to order brake and fuel lines as well as a gas tank. Looks line Inlinetubes.com has everything... and body have input?
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: InLine Tubes? [Re: JMCFAN] #1558523
01/04/14 01:10 PM
01/04/14 01:10 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
Great place to deal with. Nice fitting lines as well.
Re: InLine Tubes? [Re: JMCFAN] #1558524
01/04/14 01:15 PM
01/04/14 01:15 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Mine fit amazingly well. Only issue was there was something marked incorrectly on their web page (some time back), I told them about it and confirmed my order over the phone. Hopefully it's been fixed but I can't recall the exact details.
Very happy with the lines I purchased
Re: InLine Tubes? [Re: AAR#2] #1558525
01/04/14 01:26 PM
01/04/14 01:26 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Sorry, should have stated my comments for the tubing.
Fuel tank I purchased from Year One, needed mild modifications to be just like the original, but overall pretty happy with it.
Re: InLine Tubes? [Re: JMCFAN] #1558526
01/04/14 11:52 PM
01/04/14 11:52 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
used Inline for fuel, brake and transmission cooling lines. All fit perfectly.
You did not list transmission cooling lines. If you have an automatic, you might want to change them too.
Craig
Re: InLine Tubes? [Re: JMCFAN] #1558527
01/05/14 11:16 AM
01/05/14 11:16 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
anybody have input?
As good as they get out there. The best.
Re: InLine Tubes? [Re: Commando1] #1558528
01/05/14 01:36 PM
01/05/14 01:36 PM
Oakdale, MN
W
weazel Offline
weazel  Offline
W
Oakdale, MN
Ive used them as well! Great company to deal with and great fitting tubes. I've used them for 2 different builds. Only one small issue was with a proportioning valve. It leaked and I had to dismantle it re-tighten everything. Minor issue overall
Re: InLine Tubes? [Re: weazel] #1558529
01/06/14 12:59 PM
01/06/14 12:59 PM
As far as the lines go, I've had no problems with their lines. Their hold off/proportioning valves on the other hand I had numerous problems with! Even the replacements they sent me ended up acting like a one way valve and letting fluid go to the rear brakes but not back up to the master cylinder. Left me stranded a couple of times. Since then I have found an original and have had the original rebuilt.
Re: InLine Tubes? [Re: ] #1558530
01/06/14 03:48 PM
01/06/14 03:48 PM
MI
John L Offline
John L  Offline
MI
Got the entire brake line set for my 70 Charger, very happy with the product and will get my fuel lines from them when I need them.
