Couple of Trans Questions #1557074
12/31/13 11:04 PM
12/31/13 11:04 PM
Tucson, Arizona
clonestocker Offline OP
Tucson, Arizona
Was at the pick a part today and saw a couple of transmissions that could be interesting.
1) 1983 / 1/2 ton /6 cyl / 4 speed (kinda looks like a A-833), what trans is this and is it worth picking up?
2) 2000ish truck from mexico 3.9?, looks to have a over drive auto trans. Worth picking up?
thx
[img] [/img]
Re: Couple of Trans Questions [Re: clonestocker] #1557075
12/31/13 11:31 PM
12/31/13 11:31 PM
Probally NP833 O.D. on both
Re: Couple of Trans Questions [Re: Cab_Burge] #1557076
01/01/14 12:01 AM
01/01/14 12:01 AM
Tucson, Arizona
Tucson, Arizona
Cab, Your over here too! The second trans is a Auto. The 4 spd looks a little different than the car trans. But still has the shifter coming through the floor. Doesnt look like a truck trans.
[img] [/img]
Re: Couple of Trans Questions [Re: clonestocker] #1557077
01/01/14 12:15 AM
01/01/14 12:15 AM
I bought a NP833 O.D. trans out of a later model Ram van, it has a cast steel case and a aluminum tailshaft housing that looks like 1970 and later B and E body trans with both shifter mounts, it was complete with a floor shifter also. I've been told by others here on Moparts that those trannys where used in both the full size Ram vans and pickups As far as the Mexican produced automatics sold in Mexico, I have no idea on those
Re: Couple of Trans Questions [Re: clonestocker] #1557078
01/01/14 12:16 AM
01/01/14 12:16 AM
Poplar Bluff, Missouri
partfiler69 Offline
Still Wondering
partfiler69  Offline
Still Wondering
I had an 82 years ago with the 833. Nothing special. Not surewhat else it fit, but I do remember that it had the same yoke and driveshaft as the 727 I replaced it with.
Back from hiatus
Re: Couple of Trans Questions [Re: partfiler69] #1557079
01/01/14 12:19 AM
01/01/14 12:19 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Get the bell if you get the OD833.
I am truckless..
Re: Couple of Trans Questions [Re: 340SHORTY] #1557080
01/01/14 01:04 AM
01/01/14 01:04 AM
Tucson, Arizona
Tucson, Arizona
The bell housing is for a 6 cyl.
[img] [/img]
Re: Couple of Trans Questions [Re: clonestocker] #1557081
01/01/14 10:09 AM
01/01/14 10:09 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
There is a decent market for that trans and bell with the Slant crowd. If you can get it cheap you can make a buck.
The trans itself is not much good for anything but a low HP daily driver. There were bearing issues with them.
The auto one I am not familiar with. Might be a variation of an A-500?
Re: Couple of Trans Questions [Re: slantzilla] #1557082
01/01/14 08:02 PM
01/01/14 08:02 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
A club member that owns a '70 Superbird uses one of those transmissions in his car when he goes on long cruises. He does it to save gas (OD top gear) and excess revs on the fresh Hemi motor. He also does it to save on tickets as he knows that transmission makes him drive like a grandma
For now the OEM Hemi 4-speed sits on the shelf and he puts from show to show.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Couple of Trans Questions [Re: Polarapete] #1557083
01/01/14 09:52 PM
01/01/14 09:52 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I ran a OD 833 behind my warmed up 340-6 for 12 years with no problems in my shorty.
The Superturd that Pete is refering to happens to be powered with a HEMI..
I am truckless..
Re: Couple of Trans Questions [Re: Cab_Burge] #1557084
01/01/14 11:13 PM
01/01/14 11:13 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Cab , other way around , alum. case , iron tailhousing ...
