Couple of Trans Questions
#1557074
12/31/13 11:04 PM
12/31/13 11:04 PM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
Was at the pick a part today and saw a couple of transmissions that could be interesting. 1) 1983 / 1/2 ton /6 cyl / 4 speed (kinda looks like a A-833), what trans is this and is it worth picking up? 2) 2000ish truck from mexico 3.9?, looks to have a over drive auto trans. Worth picking up?
thx
[img] [/img]
Re: Couple of Trans Questions
[Re: Cab_Burge]
#1557076
01/01/14 12:01 AM
01/01/14 12:01 AM
clonestocker
Tucson, Arizona
Cab, Your over here too! The second trans is a Auto. The 4 spd looks a little different than the car trans. But still has the shifter coming through the floor. Doesnt look like a truck trans.
[img] [/img]
[Re: clonestocker]
#1557078
01/01/14 12:16 AM
01/01/14 12:16 AM
Posts: 223 Poplar Bluff, Missouri
partfiler69
Still Wondering
Still Wondering
I had an 82 years ago with the 833. Nothing special. Not surewhat else it fit, but I do remember that it had the same yoke and driveshaft as the 727 I replaced it with.
Back from hiatus
[Re: partfiler69]
#1557079
01/01/14 12:19 AM
01/01/14 12:19 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Get the bell if you get the OD833.
I am truckless..
[Re: clonestocker]
#1557081
01/01/14 10:09 AM
01/01/14 10:09 AM
Posts: 20,210 Park Forest, IL
slantzilla
Park Forest, IL
There is a decent market for that trans and bell with the Slant crowd. If you can get it cheap you can make a buck.
The trans itself is not much good for anything but a low HP daily driver. There were bearing issues with them.
The auto one I am not familiar with. Might be a variation of an A-500?
[Re: slantzilla]
#1557082
01/01/14 08:02 PM
01/01/14 08:02 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
A club member that owns a '70 Superbird uses one of those transmissions in his car when he goes on long cruises. He does it to save gas (OD top gear) and excess revs on the fresh Hemi motor. He also does it to save on tickets as he knows that transmission makes him drive like a grandma For now the OEM Hemi 4-speed sits on the shelf and he puts from show to show.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Polarapete]
#1557083
01/01/14 09:52 PM
01/01/14 09:52 PM
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I ran a OD 833 behind my warmed up 340-6 for 12 years with no problems in my shorty.
The Superturd that Pete is refering to happens to be powered with a HEMI..
I am truckless..
[Re: Cab_Burge]
#1557084
01/01/14 11:13 PM
01/01/14 11:13 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
I bought a NP833 O.D. trans out of a later model Ram van, it has a cast steel case and a aluminum tailshaft housing that looks like 1970 and later B and E body trans with both shifter mounts,
Cab , other way around , alum. case , iron tailhousing ...
