Page 1 of 3 1 2 3
tell me about harland sharp rockers- roller vs bushed #1555115
12/29/13 01:55 PM
12/29/13 01:55 PM
tulsa ok
U
upnover Offline OP
upnover  Offline OP
U
tulsa ok
I am needing a good set of rockers for lowdeck engine that I am changing heads/cam etc on.ez-1 heads w double springs, solid cam, street strip car that is seeing mostly strip currently, I am looking for a 1.6 rocker standard offset and have decided on either hughes or harlands, I saw some Harlands on clearance for a good price but it says that they are bushed, I went to harlands site and cant find any info on them, are they discontinued, or a lesser quality than the other(roller) ones? thanks for your time guys!
Re: tell me about harland sharp rockers- roller vs bushed [Re: upnover] #1555116
12/29/13 02:37 PM
12/29/13 02:37 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Don`t know about the bushed ones but I`ve been runnin rollerized HS`s for about 8 years street strip w/an Isky .680-.660 solid roller........
Re: tell me about harland sharp rockers- roller vs bushed [Re: Thumperdart] #1555117
12/29/13 03:04 PM
12/29/13 03:04 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I have a set of each (roller & bushed HS), no problems to report with either. The bushed style obviously does away with any fears about roller bearing failure, but I wasn't worried about that I got them, it was just a good deal on them from another racer (new in box, sitting around for years).
IIRC, Ron (383man) has a Hughes setup - don't recall if bushed/roller - but he's happy with them on his street/strip monster.
Re: tell me about harland sharp rockers- roller vs bushed [Re: upnover] #1555118
12/29/13 04:02 PM
12/29/13 04:02 PM
Delray beach, Florida
P
Performance Only Offline
P
I've installed the so called "bushed" rockers a few times on customer engines. They aren't actually bushed though. There is no bushing, just the parent aluminum from the extrusion like a Crane gold rocker. I prefer the rollerized Harland Sharps, especially if a solid roller cam will end up in the motor with higher spring pressures than the typical flat tappet cams.
One other difference is the shafts. The less expensive rockers use shafts from pioneer. they have cup plugs in the shafts and they typically spit oil out around the plugs. Every set I've installed I've had to replace the plugs to get them to stop leaking.
The better rockers use a harder shaft with screw in plugs on the ends.
Basically you get what you pay for.
machine shop owner and engine builder
Re: tell me about harland sharp rockers- roller vs bushed [Re: upnover] #1555119
12/29/13 04:07 PM
12/29/13 04:07 PM
Buy the good ones(rollers, not extruded non rollers or bushed ) and don't look back I have a set of the very early Harand Sharp 1.5 from the mid 1960s on one of my street motors, they had been abused and misused prior to me buying and using them, there still rolling right along without any issues I have bought and used several more sets of the new Harland Sharp 1.6 ratio(checked at the retainers to be 1.64 to 1.65 ) and found that like the 1.5 ratio rockers(checked out to be 1.54 ) they have more ratio than advertised, not less like a lot of the other rockers out there
Re: tell me about harland sharp rockers- roller vs bushed [Re: Cab_Burge] #1555120
12/29/13 04:40 PM
12/29/13 04:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know why they would call them a "bushed" rocker
if there isnt a bushing that can be replaced
Re: tell me about harland sharp rockers- roller vs bushed [Re: MR_P_BODY] #1555121
12/29/13 05:22 PM
12/29/13 05:22 PM
tulsa ok
U
upnover Offline OP
upnover  Offline OP
U
tulsa ok
thanks for the info, I will hold out for the roller style.
Re: tell me about harland sharp rockers- roller vs bushed [Re: upnover] #1555122
12/29/13 06:11 PM
12/29/13 06:11 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
+1 for rollerized.
If you run any " larger " cam and / or elevated spring pressure , it is the clear way to go.
Re: tell me about harland sharp rockers- roller vs bushed [Re: upnover] #1555123
12/29/13 08:50 PM
12/29/13 08:50 PM
Massillon, Ohio
cudatom Online content
cudatom  Online Content
Massillon, Ohio
My brother has a set that is at least 25 yrs old. I got them w/a car we bought in 1988. Ran them on my Cuda for 12 yrs and my brother has had then for 13. I have no idea how old they were when we got them but they had been used.
Ok
Re: tell me about harland sharp rockers- roller vs bushed [Re: cudatom] #1555124
12/29/13 09:23 PM
12/29/13 09:23 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
The nice thing about Harlan Sharp rockers is the fact that even old used ones are still worth more than new cheap ones. And a lot easier to sell if you ever want or have to.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: tell me about harland sharp rockers- roller vs bushed [Re: pittsburghracer] #1555125
12/30/13 04:00 AM
12/30/13 04:00 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
These are the bushed ( ? ) roller tip Hughes I have had on my eng for 2-1/2 years and they are holding up great. Last valve adjustment they were all still right on the money. Ron
Re: tell me about harland sharp rockers- roller vs bushed [Re: MR_P_BODY] #1555126
12/30/13 01:38 PM
12/30/13 01:38 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
IF they are the "exclusive" ones sold by Mancini's they are advertised as "bushed style".......meaning extruded aluminum.
Re: tell me about harland sharp rockers- roller vs bushed [Re: Dean_Kuzluzski] #1555127
01/04/14 12:00 PM
01/04/14 12:00 PM
tulsa ok
U
upnover Offline OP
upnover  Offline OP
U
tulsa ok
I found a set of the Harland rollers, they are supposed to be new just removed from the package, but not installed, im saving just under $100 compared to new, but for what they cost i'll take any savings that I can get, thanks guys for all of the replies!
si
Re: tell me about harland sharp rockers- roller vs bushed [Re: upnover] #1555128
01/04/14 12:30 PM
01/04/14 12:30 PM
Q
Quicktree Offline
Quicktree  Offline
Q
so what are t&d and jesel?
Re: tell me about harland sharp rockers- roller vs bushed [Re: Quicktree] #1555129
01/04/14 03:30 PM
01/04/14 03:30 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Price ? Somewhere just north of 1100.00 for individual shaft ( W-9 ), and probably slightly less for shared shaft.
Re: tell me about harland sharp rockers- roller vs bushed [Re: Quicktree] #1555130
01/04/14 03:35 PM
01/04/14 03:35 PM
Call them and find out
Re: tell me about harland sharp rockers- roller vs bushed [Re: tubtar] #1555131
01/04/14 03:41 PM
01/04/14 03:41 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The bushed HS I have do actually have bushings. Apparently - if that's not common for them - they were custom-made, which would make sense since I got them from a racer buddy who'd be likely to order something like that. And you should definitely run the hardened shafts.
Re: tell me about harland sharp rockers- roller vs bushed [Re: topside] #1555132
01/04/14 04:08 PM
01/04/14 04:08 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I bought the "bushed" HS from Mancini, they do not actually have a bushing its just the aluminum.
Re: tell me about harland sharp rockers- roller vs bushed [Re: GTX MATT] #1555133
01/04/14 10:27 PM
01/04/14 10:27 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I live about 45 min.from the HS shop and I went to see the bushed Mancini units when I first seen them. Now the ones I had in my hands had an actual bronze bushing in them Maybe they have since cheapen
them since they first came out.I prefer the bronze myself on a S/S engine.
I had a good older set of Isky rockers done up by RAS so I just stayed with them.
Gus
64 Plymouth Savoy
Dana 60
Re: tell me about harland sharp rockers- roller vs bushed [Re: Cab_Burge] #1555134
01/04/14 11:16 PM
01/04/14 11:16 PM
Q
Quicktree Offline
Quicktree  Offline
Q
that tells me you never used any anyone know if they are bushed or bearings?
Page 1 of 3 1 2 3
