Re: Manual Valve Body
[Re: 72 RR DUDE]
#1549493
12/17/13 11:27 PM
12/17/13 11:27 PM
Posts: 1,008 wv
Dartcuda
wv
[Re: Dartcuda]
#1549494
12/18/13 12:00 AM
12/18/13 12:00 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
forward
and expect to pay about $100 more for it.
[Re: Mr.Yuck]
#1549495
12/18/13 02:10 AM
12/18/13 02:10 AM
Posts: 9,110 Tucson, AZ
Ramrod39
My New Title
My New Title
Tucson, AZ
forward
Why would that be?
[Re: Ramrod39]
#1549496
12/18/13 03:15 AM
12/18/13 03:15 AM
Posts: 10,130 A Red State
SNK-EYZ
A Red State
The trans experts can explain it better, but from what I've been told you don't get the higher fluid pressure with a forward pattern manual valve body. You only get (higher pressure) that with a reverse pattern manual one. If that's the case, what the point of installing a fwd pattern manual over one that simply has a good shift kit in it? You can still manually control them.
[Re: 70AARcuda]
#1549498
12/18/13 08:44 AM
12/18/13 08:44 AM
Posts: 20,171 Park Forest, IL
slantzilla
Park Forest, IL
With a full manual you can do away with the kickdown linkage.
[Re: slantzilla]
#1549499
12/18/13 09:31 AM
12/18/13 09:31 AM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
Why would you want a forward pattern on a manual valve body You are then shifting twords reverse. The older stock type shifters don't have a good revers lockout to keep you from slamming into reverse.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
[Re: SNK-EYZ]
#1549503
12/18/13 08:28 PM
12/18/13 08:28 PM
Posts: 2,165 Inver Grove Heights MN
74RR
I've never heard that before,interesting.
[Re: 74RR]
#1549505
12/18/13 08:46 PM
12/18/13 08:46 PM
Posts: 4,710 Florida
BDW
That's why I love it here, I learn something new every day!
[Re: 72 RR DUDE]
#1549507
12/19/13 12:23 AM
12/19/13 12:23 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I run a Turbo-Action forward pattern manual VB in my Street / Strip Satellite with a B&M Quicksilver shifter. Works like a charm!
[Re: 72 RR DUDE]
#1549508
12/19/13 12:40 AM
12/19/13 12:40 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Give this one a thought.....
http://www.summitracing.com/parts/tac-17676/overview/
It is really the best of both worlds.
My wifes 72 charger has a factory slap stik. The previous owner told me he used a FWD patern manual VB with it and it worked great. When we first got the car, all I had was aa RMVB so that's hwat wwe used. I have to admit it was a terrible combination for them. (dad and wife split driving duties)
Sometimes they would short shift the 1-2 or miss 2nd all together and hit third.
I even bought the Shift R Gate thing that would make the slap stik work the same in both directions. Turns out, it doesn;t do that. What I gathered was it "slipped: the gate between 1 and 2 and then you would need to hit the button for 3.
I also wasn;t all that keen on hacking up the factory shifter so I never did install it to verfy my concerns.
I instead bought the Atuo/Mn FWD valve body and gave that a shot. I was concerned that it would not give the same neck snapping shifts that the RMVB was capable of but I was proven wrong quickly. Not only does will it shift just as firm and quick as my RMVB it's fwd pattern works great witht the slap stik and once the race is over, they can leave it in D and it reverts back to a normal atuo on the return rd and back through the pits.
Not only can I say we didn;t lose any ET with the VB swap, we actaully probably gained some as the FWD allowed them to use the shifter as t was designed and really hammer the shifts.
[Re: Ramrod39]
#1549511
12/19/13 10:23 AM
12/19/13 10:23 AM
Mr.Yuck
Brookeville, Md
forward
Why would that be?
no idea why but they are
