Manual Valve Body #1549492
12/17/13 11:01 PM
12/17/13 11:01 PM
Hamburg, Pa.
72 RR DUDE Offline OP
Hamburg, Pa.
What manual valve body do you use when you want to maintain the original shift pattern P R N D 2 1. Forward or reverse manual valve body???
Re: Manual Valve Body [Re: 72 RR DUDE] #1549493
12/17/13 11:27 PM
12/17/13 11:27 PM
wv
Dartcuda Offline
Dartcuda  Offline
wv
forward
Re: Manual Valve Body [Re: Dartcuda] #1549494
12/18/13 12:00 AM
12/18/13 12:00 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
forward
and expect to pay about $100 more for it.
Coming soon!!!!
Re: Manual Valve Body [Re: Mr.Yuck] #1549495
12/18/13 02:10 AM
12/18/13 02:10 AM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
forward
Why would that be?
Re: Manual Valve Body [Re: Ramrod39] #1549496
12/18/13 03:15 AM
12/18/13 03:15 AM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
The trans experts can explain it better, but from what I've been told you don't get the higher fluid pressure with a forward pattern manual valve body.
You only get (higher pressure) that with a reverse pattern manual one.
If that's the case, what the point of installing a fwd pattern manual over one that simply has a good shift kit in it?
You can still manually control them.
Re: Manual Valve Body [Re: SNK-EYZ] #1549497
12/18/13 03:36 AM
12/18/13 03:36 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: Manual Valve Body [Re: 70AARcuda] #1549498
12/18/13 08:44 AM
12/18/13 08:44 AM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
With a full manual you can do away with the kickdown linkage.
Re: Manual Valve Body [Re: slantzilla] #1549499
12/18/13 09:31 AM
12/18/13 09:31 AM
MICHIGAN
BB65Barracuda Offline
MICHIGAN
Why would you want a forward pattern on a manual valve body
You are then shifting twords reverse. The older stock type shifters don't have a good revers lockout to keep you from slamming into reverse.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: Manual Valve Body [Re: BB65Barracuda] #1549500
12/18/13 10:10 AM
12/18/13 10:10 AM
A Red State
A Red State
If you're got the factory slap-stick shifter I don't think that's an issue if you're running a fwd pattern valve body.
Other factory shifters I could see that possibly being an issue if they're not adjusted properly.
As it was explained to me the reverse pattern manual was the best choice because of line pressure being higher than a fwd pattern valve body.
Re: Manual Valve Body [Re: SNK-EYZ] #1549501
12/18/13 07:31 PM
12/18/13 07:31 PM
Hamburg, Pa.
Hamburg, Pa.
Yes it is Slap Stick and is anyone running the forward pattern? If so how is the performance does it shift good and solid????
Re: Manual Valve Body [Re: 72 RR DUDE] #1549502
12/18/13 08:12 PM
12/18/13 08:12 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
There is a reverse pattern plate that you can buy for your slap stick.
Re: Manual Valve Body [Re: SNK-EYZ] #1549503
12/18/13 08:28 PM
12/18/13 08:28 PM
Inver Grove Heights MN
74RR Offline
74RR  Offline
I've never heard that before,interesting.
Re: Manual Valve Body [Re: 74RR] #1549504
12/18/13 08:31 PM
12/18/13 08:31 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Is this for a street/strip car or race only?
Re: Manual Valve Body [Re: 74RR] #1549505
12/18/13 08:46 PM
12/18/13 08:46 PM
BDW Offline
BDW  Offline
That's why I love it here, I learn something new every day!
Re: Manual Valve Body [Re: BDW] #1549506
12/19/13 12:14 AM
12/19/13 12:14 AM
Hamburg, Pa.
Hamburg, Pa.
It is for street strip but mostly street.
Re: Manual Valve Body [Re: 72 RR DUDE] #1549507
12/19/13 12:23 AM
12/19/13 12:23 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I run a Turbo-Action forward pattern manual VB in my Street / Strip Satellite with a B&M Quicksilver shifter. Works like a charm!
Re: Manual Valve Body [Re: 72 RR DUDE] #1549508
12/19/13 12:40 AM
12/19/13 12:40 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Give this one a thought.....
http://www.summitracing.com/parts/tac-17676/overview/
It is really the best of both worlds.
My wifes 72 charger has a factory slap stik. The previous owner told me he used a FWD patern manual VB with it and it worked great. When we first got the car, all I had was aa RMVB so that's hwat wwe used. I have to admit it was a terrible combination for them. (dad and wife split driving duties)
Sometimes they would short shift the 1-2 or miss 2nd all together and hit third.
I even bought the Shift R Gate thing that would make the slap stik work the same in both directions. Turns out, it doesn;t do that. What I gathered was it "slipped: the gate between 1 and 2 and then you would need to hit the button for 3.
I also wasn;t all that keen on hacking up the factory shifter so I never did install it to verfy my concerns.
I instead bought the Atuo/Mn FWD valve body and gave that a shot. I was concerned that it would not give the same neck snapping shifts that the RMVB was capable of but I was proven wrong quickly. Not only does will it shift just as firm and quick as my RMVB it's fwd pattern works great witht the slap stik and once the race is over, they can leave it in D and it reverts back to a normal atuo on the return rd and back through the pits.
Not only can I say we didn;t lose any ET with the VB swap, we actaully probably gained some as the FWD allowed them to use the shifter as t was designed and really hammer the shifts.
Re: Manual Valve Body [Re: 74RR] #1549509
12/19/13 05:45 AM
12/19/13 05:45 AM
A Red State
A Red State
I've had two different transmission guys tell me that.
When I was first having my trans built I was going to use a fwd pattern manual John Cope recommended using the reverse pattern one because of the higher line pressure.
Dan Smith (qwkmopardan) told me the same thing.
They explained the why there was a difference, but rather than me trying to explain it I was hoping an expert would chime in and do that.
Re: Manual Valve Body [Re: SNK-EYZ] #1549510
12/19/13 10:18 AM
12/19/13 10:18 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
One other small advantage to the VB I mentioned is it still retains the LBA in first gear so risk of damaging the sprag is eliminated.
Re: Manual Valve Body [Re: Ramrod39] #1549511
12/19/13 10:23 AM
12/19/13 10:23 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
forward
Why would that be?
no idea why but they are
