Page 3 of 9 1 2 3 4 5 6 7 8 9
Re: Will a 8 3/4 Live? [Re: actionange] #1548277
12/17/13 04:15 PM
12/17/13 04:15 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
...I'm still using one in my 67 Belvedere running low 10s. It weighs at least 3750 lbs race ready. Leaving at approx. 2000 rpm. 1.42 60 ft so I'm not beating it at the hit.
Using Mark Williams axles, spool and Richmond gears.
Like the Everready Bunny...still going.
Sounds familiar since in my case it's...
- mid-10s
- 2000 RPM leave
- 3750#s
- 1.45 60s
... and the parts I mentioned using above.
But I'm still expecting it's a time bomb and getting more serious lately about a D60 upgrade.
Re: Will a 8 3/4 Live? [Re: BradH] #1548278
12/17/13 05:11 PM
12/17/13 05:11 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
No matter how you look at it you have to weigh out how the car will be used to see if it will hold up. Sure a street car that does not see a sticky tire it will be fine. But a car thats raced with slicks or drag radials there is a good chance something in the 8-3/4 may break sooner or later. I really want to upgrade to a Dana in my 63 but my funds are very limited right now. But the price Dr Diff has a Dana for makes me want to borrow the money and go for it. Believe it or not the 8-3/4 in my 63 is all stock other then the Detroit Locker I put in it and the 4.30 gears. I know I am running on borrowed time but I dont race my car much as I mostly drive it on the street and I dont street race. In fact I have only put 4 passes on my car in the last 2 years. Funny as back in the 80's I bracket raced a 66 Dart with a 340 and 4-speed. It had an 8-3/4 from a 68 Dart in it and I broke that rear at least 4 times between ring and pinions and carriers. I finnally went to a spool and then broke driveshafts and U-joints. It was basically a stock 833 but I launched it hard as when I let the clutch out the go pedal went to the floor all the time. It ran a best ever of 11.94 at 113 and my 63 with a stock 8-3/4 has not broke anything yet and of course its much faster and heavier but it is an auto. I have raced my 63 about 10 times since 2006 and it ran mid 11's until 2011. I have raced it 4 times with the 10 second eng in it. I dont plan to race again until I beef it up or go to a Dana. If the 8-3/4 breaks I will be going thru my trans also. Ron
Re: Will a 8 3/4 Live? [Re: actionange] #1548279
12/17/13 07:27 PM
12/17/13 07:27 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I don't want to hurt fealings or step on toes but with his set-up IT WILL BREAK!
Any diff can break with enough abuse.
I speak from experience 3800lbs 69 Roadrunner with a 10" slick, 5 speed, Cal-Tracs, around 650lbs/ft torque. I have broke axles, bent things on a Dana 60. The 8 3/4 would have destoyed it self long, long ago.
I wouldn't recommend an 8-3/4 to anyone but everybody knows that.
This has been discussed by you and I before Quicktree. I'm still using one in my 67 Belvedere running low 10s. It weighs at least 3750 lbs race ready. Leaving at approx. 2000 rpm. 1.42 60 ft so I'm not beating it at the hit.
Happy Holidays!
what size and type of rear tire do you run?
Re: Will a 8 3/4 Live? [Re: Quicktree] #1548280
12/17/13 08:27 PM
12/17/13 08:27 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Put the money in a Dana60. In 1992 when i bought my 64 Savoy the 8-3/4 lasted 3 races( chucked all the teeth off the ring gear) Got a truck Dana and used the axles, ends and brakes, bought used 4.88 gears and spool, got maybe $400 bucks in it. Cover has not been off since, guess I should check the oil this year.
Re: Will a 8 3/4 Live? [Re: cudaman1969] #1548281
12/17/13 09:02 PM
12/17/13 09:02 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
ET Streets + 5 speed = broken 8 3/4's. It will live if you never do clutch dumps with it, but then why have a clutch in the first place?
I would put a Dana 60 in it and never worry again.
Re: Will a 8 3/4 Live? [Re: Blusmbl] #1548282
12/18/13 12:46 AM
12/18/13 12:46 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
This is the results of running a 8 3/4 for 20 some years
and thats 60'ing 1.31's with a best 0f 1.28@3350 now the problem that i think is that Richmond is no longer in the gear makeing bussiness so i guess your option now or Motive,Yokoun gears ..........that's my
Re: Will a 8 3/4 Live? [Re: racerx] #1548283
12/18/13 03:21 AM
12/18/13 03:21 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
What the car 60fts and really, even what it weighs is of no consequence as to whether you will break the rear or not. WHAT matters is how well you stick the tire and how much torque it makes. If you make torque AND stick the tire, the case and pinion flexes as the pinion tries to climb the ring gear. This flex pulls the pinion gear away from the ring gear and it shears teeth. A back brace keeps you from bending the axle tubes, but does ZERO to address the chunk or pinion flex. Breaking caps, is a result of the other stuff moving around. Good caps may make the gear set last longer, but still does NOT address the problem. Even if you have a better case, such as the alum MP unit, the pinion stem is still too small. Bottom line, you are NOT going to "fix" the weakness in the 8.75, I don't care how much money you spend on it. The design is just inferior to other rears. If you make power and halfway stick the tire, you WILL break it.
As for gears, Motive bought out Richmond and all the gears are made in Italy and are actually a better quality of steel than before
Monte
Re: Will a 8 3/4 Live? [Re: Monte_Smith] #1548284
12/18/13 04:19 AM
12/18/13 04:19 AM
Q
Quicktree Offline
Quicktree  Offline
Q
Monte
there you have it in a nut shell, and nothing you can do to prevent it.
Re: Will a 8 3/4 Live? [Re: Quicktree] #1548285
12/18/13 09:12 AM
12/18/13 09:12 AM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
Happy Holidays!
9x28 Hoosier bias ply Slick or M/T 9x28 bias ply Slick
Re: Will a 8 3/4 Live? [Re: actionange] #1548286
12/18/13 09:27 AM
12/18/13 09:27 AM
Q
Quicktree Offline
Quicktree  Offline
Q
Happy Holidays!
there you have it, I did the same thing with a small 9" slick many years ago. believe it or not you are not dead hooking with that tire, you get just enough slip to let the rear live. and yes you can still lift the front wheels and have a little slip. the combo works for you right now but put a 10.5 on it and watch it explode. been there done that going from a 9" to bigger tire. Monte was spot on....
Re: Will a 8 3/4 Live? [Re: actionange] #1548287
12/18/13 09:37 AM
12/18/13 09:37 AM
Long Island, NY
Cudafied Offline
Cudafied  Offline
Long Island, NY
Running 10.'0s with a trans brake I got about 450 passes on the ring and pinion (street gears) before the ring gear would start to crack teeth 1.39-1.40 60ft. Running mid 9's with trans brake I'm getting about 75 passes (also street gears) before I start cracking teeth 1.30 60ft. I always hear it before it fully breaks the teeth off. I think it may be time for me to switch...My car weight is in my sig...
Re: Will a 8 3/4 Live? [Re: Monte_Smith] #1548288
12/18/13 01:40 PM
12/18/13 01:40 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Monte
Guess I`m not making enuff power to kill mine which is probably a blessing and 1.36 60`s are helping also I guess. Been adding up parts and prices and the 9" can get stupid expensive in a hurry so when I can I`m ordering a complete Dana-60 from Dr. Diff...........
Re: Will a 8 3/4 Live? [Re: MattW] #1548289
12/18/13 02:00 PM
12/18/13 02:00 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
How much to deliver to 13662?
Thx Matt
Re: Will a 8 3/4 Live? [Re: Thumperdart] #1548290
12/18/13 03:57 PM
12/18/13 03:57 PM
BradH Offline
BradH  Offline
Guess I`m not making enuff power to kill mine which is probably a blessing... when I can I`m ordering a complete Dana-60 from Dr. Diff...
I'm thinking the same thing...
Re: Will a 8 3/4 Live? [Re: BradH] #1548291
12/18/13 04:04 PM
12/18/13 04:04 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Which part? Not enuff power or gettin a Dana..........
Re: Will a 8 3/4 Live? [Re: Thumperdart] #1548292
12/18/13 04:07 PM
12/18/13 04:07 PM
BradH Offline
BradH  Offline
BOTH!
Gimme a "V"!
Gimme an "I"!
Gimme an "S"!
Gimme an "A"!
What's that spell?!
DANA 60!
Re: Will a 8 3/4 Live? [Re: Thumperdart] #1548293
12/18/13 05:23 PM
12/18/13 05:23 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Really Matt? You've been in this game long enough to know the real question is whether or not you want to know the weak link in your drivetrain is...
I broke two gear sets in the Mirada, went D-60 before the t-brake. Even the duster got a D-60 from Dr Diff before we had any issues.
Re: Will a 8 3/4 Live? [Re: J_BODY] #1548294
12/18/13 06:23 PM
12/18/13 06:23 PM
Tucson, Arizona
clonestocker Offline OP
Tucson, Arizona
Jay, It's John's Dart. He was getting input that an 8 3/4 would take it. He's put a 5 speed in the car and has CalTracs on the way. You know he's going to lean on it. I wanted to get more input for he to see before he dumped some coin in an 8 3/4 and then have to spend more later. How's the Duster coming along? matt
[img] [/img]
Re: Will a 8 3/4 Live? [Re: Thumperdart] #1548295
12/18/13 06:46 PM
12/18/13 06:46 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Monte
Not really true......lets look at some pricing. A junkyard 9" or Dana housing are easily found. 9" are everywhere and will be dirt cheap. A pass car Dana, if you find one in a bone yard, will cost more and a truck housing will be even heavier and require more work. Both will likely need to be narrowed, new perches, brackets etc. The Ford will require a back brace. So considering initial cost and work involved, the junkyard route is probably a wash on cost or in favor of Ford.
Aftermarket cost boils down to what you want and how much you are willing to spend on a housing. The S-60 housing is NOT cheap and Fords can be had from a couple hundred, to a couple thousand, just depends on what you want.
Axles are a wash.
Brakes are a wash. If you have Mopar brakes already, you can put Mopar ends on your Ford and reuse them. Again a wash.
A Dana spool is $225 and bearings are $74........Jegs prices
A 9" spool is $152 and bearings are $40.............Jegs prices
Gears a wash or in Ford favor depending on ratio desired, as Dana is VERY limited.
So at this point, the Ford is likely $100 or more cheaper, depending on what you did for a housing and gears.
Where the Ford costs more is the chunk.......BUT...not everybody needs an $1100 MW thru bolt case. You can get a Nodular Iron Strange case that will be fine for most street strip applications for $250 or the Nodular Pro Series case for $300. You will need an aluminum or Nodular pinion support for the Ford, depending on power level and these can range from less than $200 to more than $1000. Again depends on what you WANT to spend.
So at THIS point, the Ford might be a couple hundred more than the Ford.........but to me personally, the drop out center and less weight make the Ford the no-brainer choice for me. Despite what some purists think, there is no law that says a Mopar MUST have a Dana.
Monte
Re: Will a 8 3/4 Live? [Re: clonestocker] #1548296
12/18/13 10:28 PM
12/18/13 10:28 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
An 8.75 will handle a ton if a few things are in it in my opinion.I'f a trans brake is used it'll bust the stock caps after a while.
I built the 8.75 rear in my cuda the best it could be built Mark Williams caps,35 spline axles and we braced it end to end.The only thing that i believe was a little weak was the size of the ring and pinion.
The only reason i went with a bullet proof 9" was i was working alot of OT and could swing the cost...lol.All joking aside i did it because its 1 less thing to worry about,and the same reason i went with an ATI sfi full aluminum case in my glide.
