340 6 PAC idle solenoid
#1547561
12/14/13 09:56 PM
12/14/13 09:56 PM
Posts: 247 I DA HOE
3406pac
I DA HOE
Does anyone have a picture showing how where the idle solenoid is installed and positioned? Thanks
AAR cuda
71 rag challenger
Re: 340 6 PAC idle solenoid
[Re: 3406pac]
#1547564
12/14/13 10:29 PM
12/14/13 10:29 PM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: ademon]
#1547566
12/14/13 11:12 PM
12/14/13 11:12 PM
Posts: 247 I DA HOE
3406pac
I DA HOE
Thanks, I guess I'm just missing a screw that the plunger hits. Any particular screw and adjustment for that?
AAR cuda
71 rag challenger
[Re: ScottSmith_Harms]
#1547570
12/15/13 02:38 AM
12/15/13 02:38 AM
Posts: 247 I DA HOE
3406pac
I DA HOE
Any particular adjustment on the screw? Or just barely touching with the engine off? Thanks
AAR cuda
71 rag challenger
[Re: 3406pac]
#1547571
12/15/13 02:49 AM
12/15/13 02:49 AM
Posts: 18,157 Mass
DAYCLONA
Mass
The screw is retained with a cage nut type of assy on the end of the linkage arm, you set the hot curb idle with the solenoid energized, the solenoid "drops out" when you shut the ignition off, this is to completely close the throttle blades to prevent run-on/dieseling ...you should be able to source the needed parts directly from Holley
Mike
[Re: Troy]
#1547573
12/18/13 12:20 AM
12/18/13 12:20 AM
Posts: 3,002 Long Island, NY
shakerjoe
Long Island, NY
don't mean to hijack the OP - but what is the correct size/style/marking for the 2 bolts that mount oe 440-6 solenoid to the intake - thanks
[Re: shakerjoe]
#1547574
12/18/13 12:55 AM
12/18/13 12:55 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
2 of these
#1547577
12/18/13 05:34 PM
12/18/13 05:34 PM
Posts: 1,652 Calgary, Alberta Canada
m46rat
1971 340 4 barrels used one of these same bolts and a roll pin rather than a second bolt to retain the DR1114429 idle stop solenoid.
Would the same nut with a captive washer that is NOT toothed, and zinc plated, also be correct? They have the identical G L head markings on them. I have about a dozen NOS ones.
