340 6 PAC idle solenoid #1547561
12/14/13 09:56 PM
12/14/13 09:56 PM
I DA HOE
3
3406pac Offline OP
3406pac  Offline OP
I DA HOE
Does anyone have a picture showing how where the idle solenoid is installed and positioned?
AAR cuda 71 rag challenger
Re: 340 6 PAC idle solenoid [Re: 3406pac] #1547562
12/14/13 10:12 PM
12/14/13 10:12 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
here's one
Re: 340 6 PAC idle solenoid [Re: ScottSmith_Harms] #1547563
12/14/13 10:27 PM
12/14/13 10:27 PM
MD
floyd Online content
floyd  Online Content
MD
There's a bracket that mounts on the two rear carb bolts of the front carb
Re: 340 6 PAC idle solenoid [Re: 3406pac] #1547564
12/14/13 10:29 PM
12/14/13 10:29 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: 340 6 PAC idle solenoid [Re: floyd] #1547565
12/14/13 10:37 PM
12/14/13 10:37 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Nice pic of the solinoid, but not sure what's going on with the throttle return spring bracket, the kickdown looks like a standard 4 bbl type also. Just wondering never seen that on a 340 6 pack
Re: 340 6 PAC idle solenoid [Re: ademon] #1547566
12/14/13 11:12 PM
12/14/13 11:12 PM
I DA HOE
3
3406pac Offline OP
3406pac  Offline OP
I DA HOE
Thanks, I guess I'm just missing a screw that the plunger hits.
Any particular screw and adjustment for that?
Re: 340 6 PAC idle solenoid [Re: 3406pac] #1547567
12/15/13 02:17 AM
12/15/13 02:17 AM
I DA HOE
3
3406pac Offline OP
3406pac  Offline OP
I DA HOE
Pic 1
Re: 340 6 PAC idle solenoid [Re: 3406pac] #1547568
12/15/13 02:17 AM
12/15/13 02:17 AM
I DA HOE
3
3406pac Offline OP
3406pac  Offline OP
I DA HOE
Pic 2
Re: 340 6 PAC idle solenoid [Re: 3406pac] #1547569
12/15/13 02:18 AM
12/15/13 02:18 AM
I DA HOE
3
3406pac Offline OP
3406pac  Offline OP
I DA HOE
Pic 3
Re: 340 6 PAC idle solenoid [Re: ScottSmith_Harms] #1547570
12/15/13 02:38 AM
12/15/13 02:38 AM
I DA HOE
3
3406pac Offline OP
3406pac  Offline OP
I DA HOE
Any particular adjustment on the screw?
Or just barely touching with the engine off?
Re: 340 6 PAC idle solenoid [Re: 3406pac] #1547571
12/15/13 02:49 AM
12/15/13 02:49 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The screw is retained with a cage nut type of assy on the end of the linkage arm, you set the hot curb idle with the solenoid energized, the solenoid "drops out" when you shut the ignition off, this is to completely close the throttle blades to prevent run-on/dieseling ...you should be able to source the needed parts directly from Holley
Mike
Re: 340 6 PAC idle solenoid [Re: 3406pac] #1547572
12/17/13 02:38 PM
12/17/13 02:38 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
Pic 1
That is a repop bracket. See how there is no bump on the edge like in the picture above. I have ran those and the problem is they can flex and change you idle seed.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: 340 6 PAC idle solenoid [Re: Troy] #1547573
12/18/13 12:20 AM
12/18/13 12:20 AM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
don't mean to hijack the OP - but what is the correct size/style/marking for the 2 bolts that mount oe 440-6 solenoid to the intake - thanks
Re: 340 6 PAC idle solenoid [Re: shakerjoe] #1547574
12/18/13 12:55 AM
12/18/13 12:55 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
2 of these
Re: 340 6 PAC idle solenoid [Re: ScottSmith_Harms] #1547575
12/18/13 12:56 AM
12/18/13 12:56 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
2
Re: 340 6 PAC idle solenoid [Re: ScottSmith_Harms] #1547576
12/18/13 12:56 AM
12/18/13 12:56 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
1971 340 4 barrels used one of these same bolts and a roll pin rather than a second bolt to retain the DR1114429 idle stop solenoid.
Re: 340 6 PAC idle solenoid [Re: ScottSmith_Harms] #1547577
12/18/13 05:34 PM
12/18/13 05:34 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
Would the same nut with a captive washer that is NOT toothed, and zinc plated, also be correct? They have the identical G L head markings on them. I have about a dozen NOS ones.
Re: 340 6 PAC idle solenoid [Re: m46rat] #1547578
12/18/13 06:15 PM
12/18/13 06:15 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I've never seen an original for that application that is not toothed. It was an important detail to keep them tightly installed.
Re: 340 6 PAC idle solenoid [Re: ScottSmith_Harms] #1547579
12/18/13 08:06 PM
12/18/13 08:06 PM
m46rat Offline
m46rat  Offline
OK, just checking. My original one(for a 71 340 manual trans) was silver zinc, not gold, I assume they came both ways. It has a toothed washer like yours.
Re: 340 6 PAC idle solenoid [Re: m46rat] #1547580
12/18/13 09:00 PM
12/18/13 09:00 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes bolt plating colors varied from silver to gold
